Calculate Volume of Object Thrown into Ocean
  • Thread starter Thread starter elemnt55
    Ocean Volume
To find the volume of the object thrown into the ocean, use the formula for volume based on mass and density, which results in a volume of approximately 1.74 m³. According to Archimedes' principle, the volume of water displaced by the object is equal to the volume of the object itself. The object will float if its density is less than that of seawater, which it is not in this case, as its density is 681.0 kg/m³ compared to seawater's 1024 kg/m³. Therefore, the volume that sticks out of the water can be calculated by determining the buoyant force and the submerged volume. The discussion emphasizes the importance of showing calculations and understanding the principles involved in solving such problems.
elemnt55
An object with a density of 681.0 kg/m3 and a mass of 1183.0 kg is thrown into the ocean. Find the volume that sticks out of the water. (use pseawater = 1024 kg/m3)
You can't just "throw" the problem in this "ocean" and expect a solution. You need to give your thoughts, show your working.
Use Archimedes' principle.
Nice answer!
1. What is the volume of this object?
2. What is the volume of water it displaces?
(Again: "Archimedes' principal".)
