Ochem energy calculation - correct answer?
The discussion centers on a discrepancy between a calculated free energy difference for the equilibrium of glucose isomers and the value provided in a solution manual. The problem involves calculating the free energy change using the equation ΔG° = -RT ln(K_eq), with R set at 0.001986 and T at 298K, leading to a calculated value of -0.34 kcal/mol. In contrast, the solution manual states -0.81 kcal/mol. The user suggests that the manual's author may have incorrectly applied the natural logarithm, potentially confusing it with decimal logarithm calculations, which could explain the significant difference in values.
tandoorichicken
I think the solution manual is wrong for this problem.
The problem:
The naturally occurring sugar glucose exists in two isomeric cyclic forms. These are called [alpha] and [beta], and at equilibrium they are present in a ratio of approximately 64:36. Calculate the free energy difference that corresponds to this equilibrium ratio.
I basically used the free energy equation
\Delta G° = -RT \ln{K_{eq}}.
I used a value of 0.001986 for R and 298K for T (I assumed STP) and got a value of -0.34 kcal/mol for DG. The solution manual lists a value of -0.81 in kcal/mol.
Chemistry news on Phys.org
Looks about right --- the idiot doing the solution may have taken a natural log and multiplied it by 2.303 rather than realizing that's a hangover from the old days of decimal logs from slide rules.
It seems like a simple enough question: what is the solubility of epsom salt in water at 20°C? A graph or table showing how it varies with temperature would be a bonus. But upon searching the internet I have been unable to determine this with confidence. Wikipedia gives the value of 113g/100ml. But other sources disagree and I can't find a definitive source for the information. I even asked chatgpt but it couldn't be sure either. I thought, naively, that this would be easy to look up without...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
