Can You Measure Terminal Velocity in a Classroom Experiment?
In summary, the conversation is about a plan for investigating Stokes' law for an OCR Physics A A2 level assignment. The main question raised is whether it is possible to measure terminal velocity of a ball bearing in a class experiment and how to accurately record it. The relevant equations for Stokes' law and terminal velocity are also mentioned. A helpful website is recommended for further understanding of the topic.
Monroe
I am putting forward this plan for discussion, in the hopes that it will be helpful for myself and others also doing this for their ocr physics A A2 levels.
The task is a planning exercise where you must write a plan for the investigation of Stokes' law.
I welcome the addition of new questions to this thread and discussion about this plan.
My particular questions about this, at this time is whether it is possible to measure terminal velocity of a ball baring in a class experiment? The problem i forsee in measuring this, is knowing when terminal velocity is actually reached, and recording this. The ball can be in air or any medium.
Stokes law : F=6πrηv
F= the resistive force experienced by the sphere as it travels through the medium
r = radius of sphere
η = the coefficient of viscocity of the medium, which can be treated as a constant, unless the temperature or density of the medium changes.
v= the velocity of the sphere
When traveling at terminal velocity, the weight is balanced by the resistive force and upthrust, leading to the equation:
v = kr² where k can be considred as a constant,
such that k = 2(ρs - ρm)g / 9η
where ρs = density of sphere, and ρm = density of medium
g = gravity
http://www.ugrad.physics.mcgill.ca/labs/Reports/Sample1.htm
great site lots of info and ideas.
and it can really help you get your head around it if you don't get it.
I appreciate the effort put into this plan for the investigation of Stokes' law. It is important to have a well-structured plan in order to conduct a successful experiment.
In response to your question about measuring terminal velocity of a ball bearing in a class experiment, it is definitely possible. However, as you mentioned, the challenge would be accurately determining when terminal velocity is reached and recording it. One way to address this issue is to use high-speed cameras to capture the motion of the ball bearing and analyze the footage to determine when the velocity becomes constant.
Another approach could be to use sensors that can measure the velocity of the ball bearing at different points during its descent and plot a graph to identify when the velocity levels off. Additionally, using a variety of ball bearing sizes and conducting multiple trials can help improve the accuracy of the results.
It is also important to consider other factors such as air resistance and the shape of the ball bearing, as they can affect the accuracy of the results. Overall, it would be beneficial to have a detailed procedure and data analysis plan in place to ensure reliable and accurate results. I encourage further discussion and refinement of this plan to make it a successful and informative investigation of Stokes' law.
1. What is OCR 2009 Physics Plan?
OCR 2009 Physics Plan is a syllabus created by the Oxford Cambridge and RSA Examinations (OCR) board for the Physics subject in the year 2009. It outlines the topics, learning objectives, and assessment criteria for the Physics curriculum.
2. Is OCR 2009 Physics Plan still relevant?
Yes, it is still relevant as it serves as a foundation for the current OCR Physics syllabus. However, there may be some updates and modifications to the content over the years.
3. What are the main topics covered in OCR 2009 Physics Plan?
The main topics covered in OCR 2009 Physics Plan include Mechanics, Electric and Magnetic Fields, Waves and Oscillations, Thermodynamics, Nuclear and Particle Physics, and Astrophysics.
4. How is OCR 2009 Physics Plan assessed?
OCR 2009 Physics Plan is assessed through written examinations, practical assessments, and coursework. The written examinations test students' knowledge and understanding of the topics, while practical assessments and coursework allow students to demonstrate their investigative and practical skills.
5. Can OCR 2009 Physics Plan be used for other exam boards?
No, OCR 2009 Physics Plan is specifically designed for the OCR exam board. Other exam boards may have their own syllabus and assessment criteria for the Physics subject.
9K
12K
  • Materials and Chemical Engineering
  • Other Physics Topics
