Octahedron in Cube: Proving the Possibility
  • Thread starter Thread starter BrianKim
    Cube
The discussion centers on the existence of an octahedron within a cube, with participants questioning the validity of the claim that it cannot exist. There is confusion about the definitions and visual representations being used, leading to a debate over the clarity of the initial question. Some participants express frustration at the contradictory statements regarding the octahedron's existence. The conversation highlights the need for precise definitions and clear communication in geometric discussions. Ultimately, the possibility of proving the octahedron's existence within a cube remains a point of contention.
BrianKim
I heard somewhere that the Octahedron can't exist in the Cube exactly.
Is this true? Can't I prove that the octahedron in the cube?
Intuitively, they seems true. But I can't sure.
Mathematics news on Phys.org
Your question is not at all clear.
I meant this. I heard that this octahedron don't exist. But...
You are both drawing something and telling us it can't exist. Doesn't that bother you?
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
