MHB Odd & Even Extension of a Function: Explained
  • Thread starter Thread starter evinda
    even Extension
evinda
MHB
Hello! (Wave)
According to my notes:
For the solution of problems with differential equations it is often useful to expand to a Fourier series with period $2L$ a function $f$ that is initially only defined on the interval $[0,L]$. We could
  • define a function $g$ with period $2L$ such that $g(x)=\left\{\begin{matrix}
    f(x) & ,0 \leq x \leq L,\\
    f(-x) & ,-L<x<0
    \end{matrix}\right.$.
    So the function $g$ is the even extension of $f$.
  • We could also define a function $h$ with period $2L$ such that $h(x)=\left\{\begin{matrix}
    f(x) & ,0 < x <L,\\
    0 & , x=0,L \\
    -f(-x) & ,-L<x<0
    So the function $h$ is the odd extension of $f$.
I was wondering why we define the extensions so that the functions are defined for $x=L$ but not for $x=-L$.
Suppose that we have the function $f(x)=2-x, 0<x<2$.
Then we get the following even and odd extension respectively:$g(x)=\left\{\begin{matrix}
2-x & , 0 \leq x \leq 2\\
2+x &, -2 <x<0\\
and
2-x &,0<x<2 \\
0 & , x=0,2\\
-2+x & ,-2<x<0
Right?The graphs of the even and odd extension of $f$ will then be the following, respectively:View attachment 6577
Am I right?
The even extension is correct. The odd one is not, because the line segment from $(-2,-4)$ to $(0,-2)$ should actually go from $(-2,0)$ to $(0,-2)$. (The graph of an odd function should look the same when it is rotated through $180^\circ$ around the origin.)
Oh right... It should be as follows, right?
Yes. (Yes)
The reason that the function is not defined at $x=-L$ is that it does not need to be. The function has period $2L$, so its value at $x=-L$ must automatically be the same as the value at $x=L$.
Ah I see... Thanks a lot! (Happy)
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
