ODE- not sure if this is correct
  • Thread starter Thread starter newtomath
    Ode
newtomath
The problem is :
(y*e^(2xy) +x) + [ b* x*e^(2xy) ] y' =0. Find b so the equation is exact and solve.
I found b=1 and worked the problem to (1/2)e^(2xy) + (x^2/2)e^(2xy) + h(y); where I found h(y) to be simply c.
The answer in the text states that e^(2xy) + x^2 =c
Would I be incorrect to multiply [ (1/2)e^(2xy) + (x^2/2)e^(2xy) = -c ] by 2 to arrive at the answer since c is an arbitrary constant?
Thanks
newtomath said:
The problem is :
Thanks
I believe you are correct in multiplying through that way, absorbing the factor of 2 into the constant. However, it still will not give you the answer the text gives because you will now have e^(2xy)+x^2 e^(2xy)=c, where as the text gives e^(2xy)+x^2=c.
Thanks. My mistake, the second term is (x^2/2) , not (x^2/2)e^(2xy)
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
