Oil film thickness for total reflection 500nm
messick11
I was asked to determin the film thickness for an oil film (n=1.33) for a light beam (500 nm) to give total reflection. I could calculate refraction angle for air to oil, but have no idea as to how to approach this question.
This is an interference question. Light reflected from the front surface of the film interferes with light reflected from the back surface. For total reflection the 2 reflected waves must be in phase.
Points to consider
1) at the air/film surface a phase change of π (λ/2) occurs (there is no phase change at the film/air surface)
2) In the film the light travels a distance = 2 x thickness of the film and the wavelength changes.
Hope this gets you started !
Thank you VERY much. I never thought of it as an interference problem!
Its a pleasure. Did you get 94nm (λ/4 for the wave in the oil)?
To solve this, I first used the units to work out that a= m* a/m, i.e. t=z/λ. This would allow you to determine the time duration within an interval section by section and then add this to the previous ones to obtain the age of the respective layer. However, this would require a constant thickness per year for each interval. However, since this is most likely not the case, my next consideration was that the age must be the integral of a 1/λ(z) function, which I cannot model.
