On Physical Lines of Force: elasticity, density and the speed of light
Maxwell discusses the ratio of m to mu, noting that in certain media, this ratio is 6 to 5, which relates to the elasticity derived from forces between particle pairs. The significance of "depend entirely on pairs of particles" emphasizes a model where elasticity arises from simple interactions rather than complex structures. This approach leads to a wave equation similar to that of a vibrating string, indicating a fundamental connection between different physical systems. The discussion also touches on the origins of numerical values for elasticity and density, questioning if they align with modern electric and magnetic constants. Overall, the conversation highlights the foundational principles linking elasticity, wave propagation, and particle interactions in physics.
Dunnis
Maxwell: -"The ratio of m to mu varies in different substances; but in a medium whose elasticity depend entirely upon forces acting between pairs of particles, this ratio is that of 6 to 5, and in this case E^2= Pi*m"
Q1: What is this 6:5 ratio and how did he make that conclusion?
Q2: What is the importance of "depend entirely... pairs of particles"?
Maxwell: -"To find the rate of propagation of transverse vibrations through the elastic medium, on the supposition that its elasticity is due entirely to forces acting between pairs of particles
[PLAIN]https://www.physicsforums.com/latex_images/26/2647530-2.png
where 'm' is the coefficient of transverse elasticity, and 'p' is the density."
Q3: Again this "entirely due to pairs of particles", what is he talking about, is he saying photons are made of particle pairs, or is he describing aether as something like Dirac Sea made of electron-positron pairs, or what?
Q4: Where did he get numerical values for this elasticity 'm' and density 'p', are those two the same numbers as electric and magnetic constant in modern equations?
Q5: Did anyone notice his original "wave equation" is nothing else but the 'wave equation for vibrating string': -"The speed of propagation of a wave in a string (v) is proportional to the square root of the tension of the string (T) and inversely proportional to the square root of the linear mass (μ) of the string:
[PLAIN]https://www.physicsforums.com/latex_images/26/2647530-3.png
". - http://en.wikipedia.org/wiki/Vibrating_string
Science news on Phys.org
What are the E and m in the E^2 = pi*m?
"Pairs of particles." The wave equation is often derived using the model of a chain of particles all connected to their neighbors using springs. When he says connected as paris of particles he probably is referring to the fact that the equation assumes a rather pedestrian situation like this (as opposed to something that may have different symmetries of springiness in different direction, etc...)
Yep, the derivations are extremely similar. One case you look at particles vertically displaced from their neighbours (restoring force in the small oscillation limit of T*theta) and in the other case you look at particles horizontally displaced from their neighbours (restoring force of k*x)
Hope that was of help. The parts I didn't respond to I don't know how to.
Thread 'A quartet of epi-illumination methods'
Well, it took almost 20 years (!!!), but I finally obtained a set of epi-phase microscope objectives (Zeiss). The principles of epi-phase contrast is nearly identical to transillumination phase contrast, but the phase ring is a 1/8 wave retarder rather than a 1/4 wave retarder (because with epi-illumination, the light passes through the ring twice). This method was popular only for a very short period of time before epi-DIC (differential interference contrast) became widely available. So...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
