One Dimensional Kinematics Jet Problem
The discussion revolves around calculating the time a Boeing 747 takes to clear an intersection while decelerating. The initial approach involved using kinematic equations, but the user struggled with algebraic manipulation and obtaining the correct initial velocity. A suggestion was made to reverse the problem, treating the jet as if it were accelerating backward, which simplified the calculations. After several attempts and corrections, the final correct time to clear the intersection was determined to be approximately 1.86 seconds. The conversation highlights the importance of careful algebraic application and understanding kinematic principles.
Fumbalodian
A Boeing 747 "Jumbo Jet" has a length of 59.7 m. The runway on which the plane lands intersects another runway. The width of the intersection is 29.9 m. The plane decelerates through the intersection at a rate of 6.33 m/s2 and clears it with a final speed of 42.3 m/s. How much time is needed for the plane to clear the intersection?
V^2 = V0^2 + 2a (X - X0)
X = 1/2 (V0 + V) t
Knowns:
X0 = 0m
X = 89.6m
V0 = Unknown
V = 42.3 m/s
a = -6.33 m/s^2
t = Unknown
I began by trying to solve for the initial velocity of the jet using the first of the above equations. I am getting 95.7 m/s but I am not sure if I am simply doing the algebra incorrectly or something else. It would help to get step by step help on the algebra as well and not skip any steps.
I then used 95.7 m/s in the second equation to solve for time. For this I am getting
1.3s but the homework webpage says that isn't correct.
I have tried repeatedly to work this through and I just can't seem to get it.
Thank you
Do a trick here. Time reverse the situation. Imagine the jet is moving backward with the same acceleration (not deceleration) of +6.33 m/s^2. It's initial velo is what is given as the final velo of +42.3 m/s. Then you'll get the answer in one shot.
X = Vi*t + (1/2)at^2.
You can do this because the time for going from Vi to Vf with deceleration a is the same for going from Vf to Vi with accn a.
X = 1/2 (V0 + V) t
Knowns:
X0 = 0m
X = 89.6m
V0 = Unknown
V = 42.3 m/s
a = -6.33 m/s^2
t = Unknown
You're doing the algebra incorrectly. Can you show your steps, and we'll see where you're going wrong?
I tried plugging in the numbers to that formula but I can't seem to get the right answer.
I did it as follows.
89.6m = 42.3 m/s*t + (1/2) 6.33 m/s^2*t^2
First off, was that what you meant?
I tried to solve it using the quadratic forumula but it doesn't seem to be working out.
0= -89.6m + 42.3m/s*t +(1/2) 6.33m/s^2*t^2
t= ((-42.3 + √(42.3^2-4(-89.6)(3.17))) / (2(-89.6)))
What might I be doing wrong?
I meant exactly that.
I got 5.89 s. Find the positive root of the quadratic eqn in 't'. A matter of one minute!
Hmmm...
I tried checking that answer on the WileyPlus webpage we use and it says 5.89s is not a correct answer.
Maybe I did some arithmetical error. You don't know how to solve quad eqn? Why do you have to go to some web page?
I did it again. I got 0.93 s.
I got those answers too. The webpage is how my teacher assigns us homework which is why I am using that. It doesn't like 0.93 s either. I guess I give up. Thanks for your help though.
42.3^2 = Vo^2 - 2*6.33*89.6
Vo = 54.1m/s
V = Vo + at or 42.3 = 54.1 - 6.33t
t = (54.1-42.3)/6.33 = 1.86s
The equation you used first were the easy way to start. if you follow your steps again you should find that the initial velocity is 54.07m/s.
for the quadratic equation you need to used the initial speed not the final.
X-Xo = Vo*t + (1/2)*a*t^2.
also you are applying the quadratic formula incorrectly. you are divining by (2*constant) were you should be doing (2*a), where a is the coefficient of the squared term of the variable which is t^2 in our case
All right, I divided by an extra 2 -- the 2a in the denominator of the qudratic roots. So, 2*0.93 = 1.86.
robphy said:
Why is "X = 89.6m"?
How far does the plane travel as it passes through the intersection?
Width + length of plane.
I saw it after posting... but didn't delete it quick enough. :rolleyes:
See if the web page likes the correct answer now. And never give up.
Thanks for the help. That answer is correct.
