One question, should be a quickie
  • Thread starter Thread starter ninoslino
When connecting two coils of the same resistance in series and then in parallel to a constant-voltage line, the heat developed per minute changes significantly. The initial reasoning suggested that the heat in series would be four times greater than in parallel due to the resistance ratio. However, it was clarified that the power (and thus heat generation) is inversely proportional to resistance, meaning that the heat generated in parallel is actually greater. The correct conclusion is that the heat developed in parallel is four times greater than in series, not one fourth. Understanding the relationship between resistance and power is crucial for accurate calculations in these scenarios.
ninoslino
1. You connect two coils of the same resistance in series to a constant-voltage line. When you later connect them in parallel to the same line, the heat developed per minute, compared with the former rate is
a) the same
b) twice as great
c) one half as much
d) four times as great
e) one fourth as much
Now this is what I was thinking... since the ratio of the Reff series to Reff parallel would be 4:1, which means that the resistance would be 4 times greater in the series circuit and the resistance is proportional to the amount of heat lost... therefore the heat developed per minute would be 4 times greater. And since we want the parallel comapred to former, so parallel(heat)/former(heat) = 1/4 = one fourth = e.
Is there a flaw in my way of thinking? Thank you for your time guys (or girls).
Welcome to PF!
Right. So far, so good.
No. The rate of heat generated is the power consumed by the resistor. P = VI = V^2/R, so the power is proportional to the inverse of the resistance.
Thank you doc!
