One Variable at a Time Approach
To study material removal rate (MRR), tool wear rate (TWR), and surface finish in aluminum using EDM die sinking, start with recommended parameters based on existing literature, even if it primarily covers steel. Begin with a baseline from steel parameters and adjust them by ±25% to find suitable values for aluminum. It's important to consider the die electrode material, as it affects the parameters significantly. Manufacturers often provide performance specifications, but it's advisable to halve those figures for practical application. Taking the first step is crucial to overcoming initial uncertainty and exploring the complexities of EDM.
salah haddad
hi guys,
i am going to machine aluminum using EDM die sinking to study the MRR, TWR and Surface finish.
i have read many papers where "One Variable at a Time Approach is used" but do not understand how the input parameters are chosen or i can choose them randomly?
thanks
You should start with a recommended or best guess set of parameters. Then study one parameter at the time by plotting resulting performance against 5 or more different values of that parameter. Then try to progressively optimise the performance by cycling through the parameters making only small changes each time. That is a hill climbing search strategy. There may be other higher hills that you do not climb, so an early crude grid search of unexplored regions is worth the effort.
Likes 1 person
thanks for reply Baluncore;
as you said that "i should start with a recommended or best guess of parameters" and for those who like me lack of experience and first time run an experiment, how i know such values because the papers i have read all them machining steal no aluminum or copper using one variable at time. any advice?
thanks
Use the parameters for steel to start with and try +/– 25% variations. The parameters will be dependent on die electrode material also. The manufacturer of the machine will recommend some best performance specifications. They are advertising so divide them by two.
Your situation remains hopeless, as fear, uncertainty and doubt will paralyse you; until you take the first step.
Only then can you begin to explore the fascinating multidimensional world of EDM.
Likes 1 person
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
