How can R1 and R3 be expressed in terms of R2 and R4 in an op-amp circuit?
The discussion focuses on deriving the values of resistors R1 and R3 in terms of R2 and R4 in an operational amplifier (op-amp) circuit, ensuring that the output voltage (vo) equals v1 - 5v2. Participants confirm that the relationships can be expressed as R1 = 5R2 and R3 = (1/5)R4, emphasizing that the ratio of resistors is what ultimately matters in op-amp configurations. The superposition theorem is applied to simplify the analysis, allowing for the calculation of gains in both non-inverting and inverting configurations.
  • Understanding of operational amplifier (op-amp) circuits
  • Knowledge of resistor networks and their ratios
  • Familiarity with the superposition theorem in circuit analysis
  • Ability to derive gain formulas for non-inverting and inverting op-amp configurations
  • Study the gain formulas for non-inverting and inverting op-amp circuits
  • Learn about the superposition theorem and its applications in circuit analysis
  • Explore resistor network analysis techniques to derive relationships between components
  • Practice solving op-amp circuit problems involving multiple resistors and voltage sources
Electrical engineers, students studying circuit design, and anyone involved in designing or analyzing op-amp circuits will benefit from this discussion.
ichabodgrant
Member warned to use homework template
In the following circuit, compute the values of R1 and R3 in terms of R2 and R4, such that vo is always equal to v1 - 5v2.I have marked 3 nodes, A, B and C. v+ = v- as assumption for the op-amp.
Consider node A.
v- = v+ = v1 × (R2 / (R1+R2))
Consider node B and C.
(v- - v2) / R3 = (vo - v-) / R4
I now stick at here...
I can write R1 in terms of R2, but there exist v- and v1.
And for R3, the same problem exists.
First, is there anything wrong in my above computations?
Second, can I express R1 and R3 in terms of R2 and R4 without using other unknowns?
The two given expressions (formulas) are correct. However, I would use another approach.
Do you know the gain formulas for (a) non-inverting and (b) inverting opamp circuits?
Your circuit is a combination of both and the most simple solution uses the above mentioned formulas. This is allowed because of the superposition theorem.
That means: The output voltage is Vo = V1- 5V2 = V1*k*gain1 - V2*gain2.
It shouldn`t be a problem to solve the system (starting with gain2).
That's good stuff and all, but how do you get R1 and R3 in terms of R2 and R4?
This is a tough one!
"...compute the values of R1 and R3 in terms of R2 and R4,"
I think the task is not well formulated. For all opamp amplifiers it is only the ratio of resistors that matters.
Therefore, we have - in theory - an infinite number of resistor values which all fulfill the required ratios.
The answer can only be R2/R1=C*R4/R3 and we can select - as one possible solution - R1=R3 and R2=C*R4.
Consider node A.
You have 2 equations. both equations have extra variables (V+ and V-). so plug one equation into the other getting rid of V+ and V-. Then solve for Vo.
The equation will then look like this
Vo=XV1-YV2
you know X=1 and Y=5
so solve for the two equations and you will get the relationship between all the resistors in the form of two equations. take it one step further and solve in the form of
R1=Z and R3=T
1. In general the goal of the exercise is to find that C value
2. I don't want to just give the answer to the OP, but I do want to point for his/her sake that your solution is incorrect.
I solve it...
I had never thought of using comparing coefficients... turns out to be not too difficult...Thanks everyone
Can you tell us your solution?
R1 = 5R2
R3 = (1/5)R4
there might be some calculation mistakes...
Yes - is correct. And - as I have expected - no other results than a RATIO only (with infinite alternatives for resistor values9.
  • · Replies 18 ·
