Opent top freight train with coal
  • Thread starter Thread starter 12boone
    Coal Train
When a freight car moving at constant speed suddenly receives a large load of coal, its velocity will decrease due to the conservation of momentum. The initial momentum of the system is equal to the momentum after the coal is added, leading to a reduction in speed as the mass of the car increases. The equation m_1v_1 = m_2v_2 illustrates that since m2 (the mass after coal is added) is greater than m1 (the initial mass), the velocity must decrease. Therefore, the correct answer to the question is that the velocity of the car decreases. This discussion emphasizes the application of momentum conservation in analyzing changes in velocity due to mass alterations.
12boone
Question 3 text A freight car moves along a frictionless level railroad track at constant speed. The car is open on top. A large load of coal is suddenly dumped into the car. What happens to the velocity of the car?
Question 3 answers
It increases.
It remains the same.
It decreases. <-----
cannot be determined from the information given
Looks good to me. Use conservation of momentum to confirm.
m_1v_1 = m_2v_2
m2 is greater than m1 therefore v has to decrease.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
