Optical power lost at a pinhole
The discussion centers on modeling optical power loss at a pinhole in a solar spectrometer design. The user proposes a formula to calculate power loss based on the intensity of sunlight and the ratio of image area to pinhole area, incorporating the sun's angular size. However, concerns arise regarding the minimal power transmitted through a 20-50 micron pinhole with a 1-meter telescope. An ideal lens's light distribution at the focal plane is described by an Airy function, suggesting that comparing the Airy disk size to the pinhole size is crucial for understanding power loss. This comparison is essential for optimizing the design of the spectrometer.
lalligagger
Hi,
I am a physics undergrad designing a solar spectrometer as part of a senior design type course. If we have light incident from the sun onto some sort of telescope objective (say a single lens for simplicity, focal length "f" and aperture radius "R") and then a pinhole at the focal point (radius "r"), how do we model the power loss at the pinhole? I was thinking it'd be
Isun*(pi*R2)*[(.01*f/2)2/(r)2]
In other words, intensity times the area of the entrance aperture gives you power in, and taking the ratio of your image area over the pinhole area gives you the fraction of power that gets through. The .01 comes from the sun being approximately .01 radians in the sky. This made sense to me, but it seems like we would barely get any power through with a 1 meter telescope into a 20-50 micron pinhole. Any help would be greatly appreciated.
Science news on Phys.org
For an ideal lens used the way you are thinking (object at infinity), the distribution of light at the focal plane is given by an Airy function, which can be written as J_1(ax)/ax, just like sinc(ax) = sin(ax)/ax.
The width of the Airy disk is given by the wavelength and f-number (or numerical aperture) of the lens:
http://en.wikipedia.org/wiki/Airy_disk
For your application, simply compare the size of the Airy disk with the size of the pinhole.
Thread 'A quartet of epi-illumination methods'
Well, it took almost 20 years (!!!), but I finally obtained a set of epi-phase microscope objectives (Zeiss). The principles of epi-phase contrast is nearly identical to transillumination phase contrast, but the phase ring is a 1/8 wave retarder rather than a 1/4 wave retarder (because with epi-illumination, the light passes through the ring twice). This method was popular only for a very short period of time before epi-DIC (differential interference contrast) became widely available. So...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
