Optical problem concerning space mirror.
Designing a space-based energy satellite using a mirror to reflect sunlight to a ground photovoltaic station presents challenges due to varying angles of sunlight from different solar poles, resulting in a large illuminated area on Earth. The discussion explores potential solutions, including the use of lenses, metamaterials, or nanomaterials, but acknowledges that traditional macro devices may not effectively address the issue. A concave mirror is suggested, but it is noted that it cannot produce a sufficiently small image due to the diverse angles at which light strikes the mirror. Additionally, the constraints of mirror-image distance and focal length further complicate achieving a minimal image size. The conversation emphasizes the need for innovative approaches to overcome these optical challenges.
fatjohn
When designing a space based energy satellite for our project, we ran across the option to just use a mirror to reflect extra light to a photovoltaic ground station on earth. The main difficulty of this option is that due to the fact that the light coming from the south pole of the sun hits the mirror with a different angle then the light coming from the north pole a 336 kilometer wide circle on Earth would be illuminated.
Is there any way to overcome this problem either with a configuration of lenses or with certain metamaterials or nanomaterials? It seems to me that at a certain (focal) point on the mirror light hits it in a various different angles. This is a problem that to my knowledge cannot be overcome with macro devices. Anybody has a proposition?
Thank you for your attention.
Science news on Phys.org
Or you could just use a concave mirror
You are trying to make an image of the sun on the ground
Yes I am trying to make an image of the sun on the ground but i am trying to make that image as small as possible. A concave mirror cannot do the job this is because at one point of the mirror the light comes in at a variaty of angles.
That is true of any lens or mirror making an image of a finite object.
You have an extra constraint that the mirror-image distance (and so focal length) is restricted which sets the minimum size of the image.
Thread 'A quartet of epi-illumination methods'
Well, it took almost 20 years (!!!), but I finally obtained a set of epi-phase microscope objectives (Zeiss). The principles of epi-phase contrast is nearly identical to transillumination phase contrast, but the phase ring is a 1/8 wave retarder rather than a 1/4 wave retarder (because with epi-illumination, the light passes through the ring twice). This method was popular only for a very short period of time before epi-DIC (differential interference contrast) became widely available. So...
I am currently undertaking a research internship where I am modelling the heating of silicon wafers with a 515 nm femtosecond laser. In order to increase the absorption of the laser into the oxide layer on top of the wafer it was suggested we use gold nanoparticles. I was tasked with modelling the optical properties of a 5nm gold nanoparticle, in particular the absorption cross section, using COMSOL Multiphysics. My model seems to be getting correct values for the absorption coefficient and...
