Optics problem, adding quantities
The discussion revolves around the problem of summing two sine functions, Y1=sin(Wt) and Y2=sin(Wt+30 degrees). The initial attempt incorrectly simplifies the expression without applying the appropriate trigonometric identities. Participants emphasize the need to use trigonometric identities to correctly combine the two sine functions. The connection to optics is questioned, indicating uncertainty about the relevance of the problem to the course material. Proper guidance on using trigonometric identities is sought to resolve the confusion.
thezac11
-Find the sum of the two quantities:
Y1=sin(Wt) Y2=sin(Wt+30 degrees)
Y(x,t)=AsinK(kx+Wt) <------- not sure if this is relevant
W=2(3.14)f , where f=frequency
sin(Wt) + sin(Wt+30) = sin(Wt) + sin(Wt) + sin(30) = 2sin(Wt) + 0.5
-This is all I've got. I'm really not sure how to go about this problem, I know there something more to it than simply adding the quantities as I did. This problem is in the Optics section of my physics course, but I'm not sure how it relates to optics. Any help would be greatly appreciated.
hi thezac11! :smile:
sorry, but that doesn't work at all :redface:
you need to look up your trigonometric identities :wink:
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
