Optics question, locate mirror and its focal length
The problem involves a 10 cm tall object placed at the zero mark of a meter stick, producing an upright, 4 cm tall image at the 42 cm mark, indicating the use of a convex mirror. The mirror's location can be determined using the mirror formula 1/do + 1/di = 1/f, where do is the object distance and di is the image distance. The object distance is 0 cm, while the image distance is -42 cm (since the image is virtual). The focal length can be calculated from the derived distances, confirming the mirror's convex nature. The solution requires careful ray diagram analysis to pinpoint the mirror's exact location and focal length.
SlothNast
"An object 10 cm tall is placed at the zero mark of a meter stick. A spherical mirror located at some point on the meter stick creates an image of the object that is upright, 4 cm tall, and located at the 42 cm mark of the meter stick. Where is the mirror located and what is the focal length?"
1/do + 1/di = 1/f
What have you done so far?
Well I've determined it must be a convex mirror, for the upright and miniature image. I have drawn a few rays from the real 10 cm object to the 4 cm image, but I am not sure how to find the location of the mirror and its focal point from that.
What rays in particular have you tried? Just two rays is enough.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
