Optics - Re-aligning P Polarization with Brewster Windows
The discussion centers on the optical engineering challenge of re-aligning P polarization using two enhanced ZnSe Brewster windows for a near-infrared laser at 10.6μm. The user, Steve, seeks to derive an expression for the angle of the second Brewster window (theta2) in relation to the first (theta1) to achieve perfect polarization alignment. He has already accounted for the refractive indexes and transmission coefficients of the Brewster windows and has calculated the final transmission. The goal is to ensure that the J component equates to zero for successful re-alignment.
  • Understanding of Brewster's Law and Brewster windows
  • Knowledge of refractive index and transmission coefficients
  • Familiarity with optical engineering concepts related to polarization
  • Proficiency in mathematical modeling for optical systems
  • Research the mathematical derivation of Brewster angles for multiple interfaces
  • Explore the impact of refractive index variations on polarization alignment
  • Study the use of enhanced ZnSe materials in optical applications
  • Learn about polarization management techniques in laser systems
This discussion is beneficial for optical engineers, laser system designers, and researchers focused on polarization management in optical applications.
SteveeGeorge
Hi all,
I have a problem, and in need of some help.
I am an optical engineer, currently designing an attentuator for near infrared lasers (10.6μm). The attenuator consists of two enhanced ZnSe Brewster windows that rotate in opposite directions and different angles to exactly re-align polarization.
I have attached my calculations as images, so to display each step of my workings. I have accounted for the refractive indexes and transmission coefficients of both brewster windows. My objective is to formulate an expression for the 2nd brewster window angle in respects to the 1st brewster window angle to perfectly realign the P polarization, which I have taken to be in the X direction:
Here is the coordinate transforms and the transmission of the first Brewster windows (internal and external surfaces).
After calculating the final transmission of both windows, I assumed that since the angle of polarization is respective to x direction, the J component equates to zero (Re-alignment).
How do I formulate an expression for theta2, respective to theta1?
If anyone could shine some light on my problem, it would be greatly appreciated!
Thanks
-Steve
Science news on Phys.org
Problem Solved / Thread closed
-Steve
9K
  • · Replies 16 ·
10K
