Optimal Wheel Design: Is Moment of Inertia the Key Factor?
  • Thread starter Thread starter David Laz
    Design
The discussion centers on the optimal design of car wheels, focusing on factors like weight, structural integrity, and moment of inertia. While moment of inertia is considered important, its significance may vary compared to other performance factors, especially between cars and motorcycles. The ideal wheel design is highly dependent on specific vehicle requirements, including weight, intended use, and material choices. Additionally, considerations such as cost, ease of replacement, and aerodynamics play crucial roles in determining the best wheel design for various conditions. Overall, achieving an optimal wheel design involves balancing multiple variables tailored to the specific vehicle and its intended application.
David Laz
Hey guys
I'm wondering if there is an 'ideal' design for a wheel for a car. I guess things that would be taken into account would be weight, structural integrity and the designs moment of inertia.
I would imagine there would be ideal designs that minimized the moment of inertia and thus would be very desirable for motorsport, however you see performance wheels take on all sorts of designs.
How important is moment of inertia of a wheels design? Is it rather insignificant compared to other factors that contribute to performance?
I'm under the impression its less important for cars then it is for motorbikes (due to engine pwr/tq characteristics?)
Like, given a certain material, surely there would be an optimal design that minimized the wheels moment of inertia and offered best possible performance.
Any insights?
You would have to be very specific about the target vehicle to obtain an "ideal" wheel design. The wheel's specifications will rely on myriad variables -- vehicle weight, intended usage (passengers, cargo, racing, etc.), dynamic loading, aerodynamics, choice of materials...
Hmm I see. I guess I was asking somewhat of an ill defined question.
Cheers.
Greetings to all. If I may make my own query here, since the thread relevance of it, I'd like to redefine David's thread-start post...
For a case study, say, I list the primary requirements (essentially in order of preference) for the 'ideal' wheel design:
- low weight
- cost effective
- capable of rapid replacement in the event of a puncture or other damage
- material choices: Al/Mg alloys, composites
- rapid(or high level ease of) manufacture
- a production vehicle (consider most common categories: compact/sub-compact/supermini cars)
- climate conditions: varied from humid to dry, low to high temperature (the optimal range)
- aerodynamic, (enhancing vehicle mileage)
Any ideas or comments on any of the listed points are welcome. Thanks in advance.
we beat this one to death..see the following post
Alloy wheels and fuel economy Apr7-11, 03:29 AM
Thanks Ranger Mike for sharing some links in the other thread which turned out to be of immense help. Cheers!
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
