Optimization problem (imaging science)
The discussion revolves around optimizing the source-to-object distance in a transmission imaging system with specified parameters. The goal is to compute the optimal distance (S1) and the corresponding full width at half maximum (FWHM) of the total point spread function (PSF) at the object plane. The user plans to derive the optimal distance by taking the derivative of the FWHM equation with respect to 'a' and setting it to zero. The expected results are an optimal distance of 96.1 cm from the focal spot and a FWHM of 0.98 mm for the object PSF. Clarification is sought on determining the 'a' dependent factor without the need for exponential functions.
richard7893
Assume a transmission imaging system with the following parameters: focal spot PSF
equal to a Gaussian with FWHM = 0.5 mm, a detector PSF equal to a Gaussian with
FWHM = 0.1 mm, source-to-detector distance = 100 cm. Compute:
1. the optimal source-to-object distance
2. the FWHM (in mm) of the total PSF at the object plane at this optimal source-to object distance.
a= S1/(S1+S2); b=S2/(S1+S2); where S1 is the distance from focal spot to object, S2 is the distance from the object to the detector, & S1+S2 is the distance from the focal spot to detector (100cm).
a+b=1 (S1 + S2 have to add to 100cm, the detector-source distance)
FWHM_object plane = ( (an 'a' dependent factor *FWHM_focal spot)^2 + (an 'a' dependent factor *FWHM_detector)^2)^(1/2) ==> (pythagorean, in case the text looks confusing. Hard doing this without pencil & paper).
I know I have to take the derivative wrt 'a' of the FWHM_obj plane equation, set it equal to 0 and solve for 'a'.
I know at this distance,'a', the PSF of the object is smallest because it's FWHM is at a minimum, making that location the optimum place to put the object.
Ultimately I'm trying to solve for S1 which I'll know once I find the value of 'a'.
The answer is supposed to come out to: 96.1cm, this is how far the object needs to be from the focal spot. And the FWHM of the object PSF is 0.98mm. I just don't know how to arrive at these numbers.
My teacher gave me the above equations, but I just don't know what the 'a' dependent factor needs to be.
And my prof. also said I didn't need to use any exponentials, even though the problem mentions gaussian functions in it.
Any help will be appreciated.
any answers ?
