Optimization using differentiation
A_Munk3y
http://i53.tinypic.com/1zu5ty.jpg
well so far, all i got is 3x + y = 3000; also y = 1000/x ==>> 3x+ (1000/x) = 3000
i don't know what the area should be though...
would it be A=x2y
If i am right in that, would i do this after
i should get the domain
get derivative
plug in x to original equation to get abs max. Also plug in x to the equation of "y" to get the #?
why y=1000/x ??
Area=xy ---> this needs to be differentiated, which would yield the value to x or y
so the area would be xy??
yes...it should be
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
