Optimization Using Differentiation
izmeh
[SOLVED] Optimization Using Differentiation
I have an assignment in which we are to optimize problems using a given 6-step process. More or less it involves Max/Min differentiation.
On of the problems are as follow;
Enclosing the Largest Area
The owner of the Rancho Los Feliz has 3000 yd of fencing material to enclose the rectangular piece of grazing land along the striaght portion of a river. If fencing is not required along the river, what are the dimensions of the lagrgest area that the he can enclose? What is the area?
I under stand that...
a=xy
p=2x+2y
i understand one of the sides can be added to the other 3 sides, however, I'm not sure how to make this a function.
Try figuring out the area of the enclosure based on the length of one of the sides:
A(x)=blah blah blah.
you should be able to construct a function like that.
P.S. The farmer doesn't have to put fence where the river is, so you should probably use:
p=2x+y
What you have to do is substitute one into the other.
a = xy
p = x + 2y
lets rearrange the perimeter equation in terms of x
x = p - 2y
and since we know p, we can can a bit farther
x = 3000 - 2y
since x = 3000 - 2y
a = (3000 - 2y)y
a = 3000y - 2y^2
since the area changes when we change the y, let's find when our differential
da/dy = 3000 - 4y
since the maximum area is when the area stops increasing, we equate to 0
0 = 3000 - 4y
after solving, we get
y = 750
now fill that back into our original equation of x = 3000 - 2y
x = 3000 - 2(750)
now solve
x = 1500
now fill in for the area formula, a = xy
a = 1500 * 750
a = 1125000
Right on :smile:
