What Determines the Direction of Twist in Helical Wavefronts?
In summary, the conversation discusses the discovery of orbital angular momentum in light and its properties, including spin and linear momentum. The participants also discuss the use of diffraction gratings to create "twisted" light and the direction of the twist. The conversation ends with a question about the interference pattern created by combining different types of light.
jby
Have you guys heard of this:
http://www.sciam.com/article.cfm?chanID=sa006&colID=5&articleID=0001A73A-45BC-1F7F-82D883414B7F0000
No, I hadn't, I know light has spin angular momentum, but I never realized it had orbital angualr momentum too.
Yes! I just got that, I had never heard of it before. I'm planning to do as the article says and go get the diffraction grating from that website one of these days. Edit: I just went to the page and see that it doens't have the whole aricle, I just assumed it did...
The entire article was not available, but here are some info sites on the subject:
http://www.aias.us/pub/OAMLight/oamlight.html
It also has links to 2 research groups.
Here are some articles from the Los Alamos arXiv:
http://arxiv.org/PS_cache/quant-ph/pdf/0308/0308093.pdf
http://arxiv.org/PS_cache/quant-ph/pdf/0111/0111112.pdf
http://arxiv.org/PS_cache/astro-ph/pdf/0307/0307430.pdf
so the photon as linear momentum(P=E/c),spin(intrinsic angular momentum),and now we find out it has orbital angular momentum. Is there any other momenta associated with a photon?
P.S.
What does intrinsic mean anyway?
P.S.
Instrinsic means that it is a fundmanetal property of the photon, i.e. all photons have a spin quantum number(s) of 1 which is related to the spin angular momentum by:
√s(s+1)h/2π
As far as I'm aware, there are no other sorts of angular momentum other than those described associated with the photon (excpet for things like total angualr momentum which is the sum of spin and orbital angular momentum).
Where are you guys getting the idea that we didn't know that light has orbital angular momentum?
No, it was just that I didn't know light had orbital momentum.
√s(s+1)h/2π
Thank you :smile:
The forked grating at http://departments.colgate.edu/physics/research/optics/oamgp/gp.htm
does not seem to have any assymmetry that would decide the direction of twist. What then determines whether the helical wavefront is right or left handed?
[Edit: The Sci Am article referred to in the original post contains a link to the site mentioned here. The page contains a grating pattern that let's anyone create "twisted" light using a laser pointer.]
quote from paper:
If we calculate the interference pattern generated by combining LG00 and LG0+1...
What would the pattern look like if it is generated with the left handed LG0-1? It must be something like a negative image.
What is orbital angular momentum?
Orbital angular momentum is a physical quantity that describes the rotation of an object around a fixed point, also known as its center of rotation.
How is orbital angular momentum measured?
Orbital angular momentum is measured by multiplying the mass of an object by its velocity and its distance from the center of rotation.
What is the significance of orbital angular momentum in physics?
Orbital angular momentum is an important concept in physics as it helps explain the motion of objects in circular or elliptical orbits, such as planets around the sun.
Can orbital angular momentum be changed?
Yes, orbital angular momentum can be changed by altering the mass, velocity, or distance of an object from its center of rotation.
What are some real-world applications of orbital angular momentum?
Orbital angular momentum has several real-world applications, such as in satellite communication, planetary motion, and quantum mechanics.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
