Orbital Period Units Question
In summary, an Earth satellite is observed to have a height of 100 n mi and a height of 600 n mi. The period of the orbit is .744 seconds.
oneredballoon
An Earth satellite is observed to have a height of perigee of 100 n mi and a height of apogee of 600 n mi. Find the period of the orbit.
(1) Period = (2*pi/sqrt(mu)) * A^(2/3)
(2) rp+ra = 2A
Where:
Mu is the Standard Gravitational Parameter 4X10^5 (km^3/s^2)
rp is radius of periapsis
ra is radius of apoapsis
A is the semi-major axis of an elliptic orbit.
I converted nautical miles to km, and used equation (2) to obtain A=648.2 km.
(185.2km+1111.2km)=2A; A =648.2km
I then plugged my value of A into the Period equation to obtain an answer of .744.
I can't quite figure out the units for this number. It looks like it would be seconds, but that seems like a pretty unreasonable solution if it is.
I know orbital periods are usually calculated in AU, but if I calculate in AU, I don't know what to do with the constant Mu, which is in km^3/s^2.
Any help would be greatly appreciated! Thanks!
An astronomical unit (AU) is the distance from the Earth to the sun, and it is not a measure of time.
In your original calculations, what happened to the Earth when you were figuring the dimensions of the orbit?
I should have phrased that better; I meant that the distances are usually in AU, not the period.
I'm not sure if I understand what you mean by "what happened to the earth"...the Earth's mass is taken into account in Mu which is G*M where G is the gravitational constant, and M is the mass of the earth.
Does 648 km look like a reasonable semimajor axis for a satellite circling the Earth? What's the diameter of the Earth in km?
AU distance units are commonly used when the object is orbiting the Sun. The assumption then is that you'll be using the Sun's gravitational parameter, [itex]\mu_{Sun}[/itex], and time units of about 58.13 days (yes, I know it looks odd!).
Since your satellite is orbiting the Earth you could use the appropriate canonical units: The distance unit DU is the radius of the Earth, the time unit TU is [itex]\sqrt{\frac{DU^3}{\mu_{Earth}}}[/itex], about 806.82 seconds. Alternatively, simply convert everything to mks units and proceed. Unless you're specifically doing work in astrodynamics, you'll probably find the latter option preferable.
Thank you for the response!
My problem was that I hadn't taken into account the radius of the earth. (I also typed the formula above incorrectly.)
Interestingly enough, this was a homework problem for my Astrodynamics class.
1. What is an orbital period unit?
An orbital period unit is a unit of measurement used to describe the time it takes for an object to complete one orbit around another object. It is typically measured in seconds, minutes, hours, days, or years, depending on the size and speed of the orbiting object.
2. How do scientists calculate orbital period?
Scientists calculate orbital period by using Kepler's third law, which states that the square of the orbital period is proportional to the cube of the semi-major axis of the orbit. This means that by knowing the distance between the two objects and their masses, scientists can determine the orbital period.
3. What is the most common unit of measurement for orbital period?
The most common unit of measurement for orbital period is the Earth's sidereal year, which is the time it takes for the Earth to complete one orbit around the Sun relative to the stars. It is equivalent to 365.256 days.
4. Can orbital period vary for different objects?
Yes, orbital period can vary for different objects depending on their distance from the object they are orbiting, their mass, and their speed. For example, the orbital period of a satellite orbiting Earth is much shorter than that of a planet orbiting the Sun.
5. How does the orbital period affect the behavior of objects in space?
The orbital period of an object affects its behavior in space by determining its speed and trajectory. Objects with shorter orbital periods have faster speeds and closer orbits, while objects with longer orbital periods have slower speeds and more distant orbits.
