Orbital Velocity due to a Dark Matter Halo
Dovahkiin
I am struggling to calculate the gravitational force from a dark matter halo given that its density is given by ρ(r) = ρ0r02/r2. Once i have found the force i plan to equate it to the centripetal force, F = mv2/r, to find the velocity, v.
Density of DM halo: ρ(r) = ρ0r02/r2
Centripetal Force: F = mv2/r
Gravitational force: F = GMm/r2
Mass of DM: M = ∫ρ dV = 4∏∫(from 0 to R) ρ(r) dr
I (think) i can see what i need to do but using a density ρ(r) = ρ0r02/r2 and trying to integrate from 0 (centre of halo) to R (radial position of the orbiting object) obviously gives and infinite mass?
However the answer is given to be:
v2 = 4∏Gρ0r02
I can't see how you could get to this answer without modifying the density, or am I incorrectly assuming that the force of a mass distribution is the same as the total mass centred at the "origin"?
Any help will be much appreciated... this question seems like it should be pretty trivial but I'm stumped!
Dovahkiin said:
ρ(r) = ρ0r02/r2
... using a density ρ(r) = ρ0r02/r2 and trying to integrate from 0 (centre of halo) to R (radial position of the orbiting object) obviously gives and infinite mass?
Shouldn't your integration measure include a r2 (thus cancelling that pesky badly behaved explosion at r=0)?
(doh!)
(doh!)
I knew I would have missed something simple ;) Thanks!
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
