Orbital velocity of a craft at 4km above the Moon's surface
The orbital velocity of a craft at 4 km above the Moon's surface can be calculated using the formula √(GM/r), where G is the gravitational constant and M is the Moon's mass. For practical purposes, the escape velocity from the Moon can be divided by √2 to estimate this velocity. The recommended value for G in SI units is 6.674 x 10^-11. It's important to note that the mass of the craft does not affect the orbital velocity. Additionally, due to lunar mascons, low orbits may be irregular and non-circular.
Fred Bobo
What would be the orbital velocity of craft at 4km above moon surface?
Assume a mass of 1,000,000 lb, US.
Astronomy news on Phys.org
For a circular orbit, it's ##\sqrt{\frac{GM}{r}}## where ##G## is the gravitational constant, ##M## is the mass of the body being orbited (here: Moon), and ##r## is the distance from the centre of the body. The mass of the craft doesn't matter.
Find the values on Wikipedia and plug them in. Or, you can make it even easier, and take the escape velocity listed on Wikipedia's page about the Moon, and divide it by ##\sqrt{2}##. The result will be only marginally off.
Thank you.
You want the one in SI units. Use ##6.674*10^{-11}##. You don't really need more significant numbers as it won't make much of a difference. Then use mass M in kilograms and distance r in metres - again, don't bother with too many significant numbers, unless you really feel like it matters to you if the result is very precise.
Thank you. All good now.
Care: Due to the lunar mascons, low orbits are seriously non-circular, unto 'lumpy'...
