Order of Convergence (mostly a limits question)
  • Thread starter Thread starter darkchild
    Convergence Limits
darkchild
SOLVED: Order of Convergence (mostly a limits question)
Sequence: xn = (2x3n-1 + a)/3x2n-1. It is given that it converges to the cube root of a.
Verify that the order of convergence of this sequence is quadratic; i.e., verify that
lim absolute value(En)/E2n-1
n->infinity
exists and is positive.
E represents the error in the nth term of the sequence; it is given that En = a1/3 - xn
Hint: consider (u+2v)(u-v)2.
I plugged the expression for xn into En, and used En-1 = a1/3 - xn-1. Then I substituted u = a1/3 and v = xn-1 and factored. My final limit:
lim abs((u+2v)(u-v)2)
n->inf. 3v2(u-v)2
My problem is that I have no idea how to take this limit using the variable n. Even if I had left this expression in terms of a1/2 and xn-1 I wouldn't know what to do, because I don't know how to work in how x changes as it's <i>subscript</i> goes to infinity.
From the hint, (u + 2v)(u - v)^2 = (u + 2v)(u^2 - 2uv + v^2) = u^3 - 3uv^2 + 2v^3
It's given that x_n = \frac{2x_{n - 1}^3 + a}{3x_{n - 1}^2}
and you want to show that \lim_{x \rightarrow \infty} \frac{E_n}{E_{n - 1}^2 } &gt; 0
So \frac{E_n}{E_{n - 1}^2} = \frac{a^{1/3} - x_n}{(a^{1/3} - x_{n - 1}^2)^2}
= \frac{a^{1/3} - x_n}{a^{2/3} - 2a^{1/3}x_{n - 1} + x_{n - 1}^2}
Now, substitute for x_n in the numerator, and you should eventually get to this:
\frac{-a + 3a^{1/3}x_{n - 1}^2 - 2x_{n - 1}^3}{3x_{n - 1}^2(a^{2/3} - 2a^{1/3} + x_{n - 1}^2)}
The numerator looks a lot like the result from the hint, but with the signs reversed, and with u = a^(1/3), and v = x_(n - 1). Using the hint will simplify the final expression above to something that involves a^(1/3) and x_(n - 1).
In the limit, I think it's reasonable to assume that x_(n - 1) converges to a^(1/3), and you should end up with a limiting value that is positive, which is what you wanted to show for quadratic convergence of this method -- Newton's method or Newton-Raphson, it looks like.
Mark
Thanks.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
