Oribit integrator for a logarithmic potential
The discussion focuses on developing an orbit integrator for a logarithmic potential defined by a specific equation. The user is attempting to solve the equations of motion derived from the potential using methods like Runge-Kutta or leapfrog but is uncertain about decoupling the system of equations. It is noted that while separating variables may not be feasible, the Runge-Kutta method can still be applied directly to the equations. A Hamiltonian approach is also mentioned, but the user struggles with adapting Runge-Kutta for the dependent variables x and y. The response clarifies that applying the method to all four equations at each step is straightforward and feasible.
Serna
Hello! Right know I'm trying to make an orbit integrator for solving a logarithmic potential with the form:
\begin{equation}
\Phi= \frac{v_0^2}{2} ln(x^2+ \frac{y^2}{u^2} + r_0^2)
\end{equation}
where v0, u, and r0 are constants
My approach is to use,
\begin{equation}
\ddot{q} = -\bigtriangledown \Phi
\end{equation}
Then the system equations,
\begin{equation}
\ddot{x} = -v_o^2 \frac{x}{x^2+ \frac{y^2}{u^2} + r_0^2}
\end{equation}
\begin{equation}
\ddot{y} = -\frac{v_o^2}{u^2} \frac{y}{x^2+ \frac{y^2}{u^2} + r_0^2}
\end{equation}
My guess is that in order to solve for x and y using Runge Kutta or leapfrog, I need to decouple the system, but I don't know how to do so.
Astronomy news on Phys.org
If by decouple the system, you mean separate the variables, it probably is not possible. But Runge-Kutta can be used to integrate the equations of motion as is. The Hamiltonian formulation (four equations with first derivatives) is usually easier.
Hello, thanks for your response!
By doing the Hamiltonian approach I still get equations (3) and (4) above, and the other two are are apparently of no use.
The problem is that I don't know how (if possible) to adapt the Runge-Kutta using two dependent variables (x,y) and the independent one (t).
Sure it is possible. It is very straightforward. Just apply the method to all four equations at every step of the code.
Publication: Redox-driven mineral and organic associations in Jezero Crater, Mars Article: NASA Says Mars Rover Discovered Potential Biosignature Last Year Press conference The ~100 authors don't find a good way this could have formed without life, but also can't rule it out. Now that they have shared their findings with the larger community someone else might find an explanation - or maybe it was actually made by life.
TL;DR Summary: In 3 years, the Square Kilometre Array (SKA) telescope (or rather, a system of telescopes) should be put into operation. In case of failure to detect alien signals, it will further expand the radius of the so-called silence (or rather, radio silence) of the Universe. Is there any sense in this or is blissful ignorance better? In 3 years, the Square Kilometre Array (SKA) telescope (or rather, a system of telescopes) should be put into operation. In case of failure to detect...
Thread 'Could gamma-ray bursts have an intragalactic origin?'
This is indirectly evidenced by a map of the distribution of gamma-ray bursts in the night sky, made in the form of an elongated globe. And also the weakening of gamma radiation by the disk and the center of the Milky Way, which leads to anisotropy in the possibilities of observing gamma-ray bursts. My line of reasoning is as follows: 1. Gamma radiation should be absorbed to some extent by dust and other components of the interstellar medium. As a result, with an extragalactic origin, fewer...
