Deriving Oscillating Universe Result: Need Help
p.p
Does anyone know how to derive the result for an oscillating universe?
R(t)= sqrt(3/lambda)sin(sqrt((3/lambda)ct)
I would appreciate the help on this one
I'm not sure what particular derivation you're after, but presumably in the RW metric there are such K and rho that give such a universe as a solution. You have the solution so why not plug it into the Friedmann equation and solve for K and rho? I think K=-1 and rho=lambda/3 would give this solution.
From integral( dR/(sqrt(lambda*R^2/3) - K) = ct
derivation has the initial conditions;
lambda<0
K=-1
Leading to the oscillating universe
Sorry, the answer I gave you is not correct. lambda can't be negative because then the argument inside sine would be imaginary and thus it wouldn't be an oscillating solution. But the method should work. Just plug your solution inside the Friedmann eq and find K and rho. There can be many pairs of K and rho that give such a solution.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
