Oscilloscope Sensitivity and Voltage Analysis
  • Thread starter Thread starter reconrusty
    Oscilloscope
The discussion revolves around analyzing an oscilloscope display to determine the amplitude and frequency of a sinusoidal voltage signal. The vertical sensitivity is given as 5mV/cm, and the horizontal sensitivity is 0.5μs/cm, with the amplitude visually represented on the oscilloscope screen.
  • Participants discuss the meaning of the vertical and horizontal sensitivity values and how they relate to the displayed waveform. There is uncertainty about the correct interpretation of amplitude as peak or peak-to-peak. Questions arise regarding unit conversions and the implications of the measurements shown on the oscilloscope.
Some participants have provided insights into the interpretation of the oscilloscope readings, while others have confirmed their understanding of the amplitude calculation. There is ongoing exploration of how to determine the frequency from the waveform period, with some participants expressing confusion about the units for frequency.
Participants are working under the constraints of interpreting oscilloscope data and ensuring correct unit conversions, with some uncertainty about the definitions of amplitude and frequency in this context.
reconrusty
In the oscilloscope display above, the vertical sensitivity is 5mV/cm, and the horizontal sensitivity is 0.5μs/cm.
A) find the amplitude of the sinusoidal voltage
B) find the frequency of the sinusoidal voltagehttp://imgur.com/fnkXliz
im not sure which equations to use for this question, if any are needed.
I know you have to convert the units in this question I am assuming. It also says in the question that each block is 1cm by 1 cm, and the top of the amplitude is about 3.2 cm, but that isn't the correct answer.
Ask yourself, what does it mean when it says 5 mV/cm? And so, what does it mean if you have a wave 3.2 cm tall on the screen?
Ask yourself, what does it mean when it says 0.5μs/cm? And how long (in cm) is one wave of the signal on the screen? And so, what does that mean?
i think it means (and correct me if I am wrong) that there is 5 megavolts (5000000 volts) in every centimeter on the y-axis. So if the wave is 3.2 cm tall would you multiple 5mV by 3.2 to get the amplitude?
First of all, mV is milliVolts, not MegaVolts... :-)
Next, I see the vertical amplitude as a little over 6 divisions tall. So the peak-to-peak amplitude will be a bit over 6 * 5mVpp. It's hard to tell if the question is asking for the peak or peak-to-peak "amplitude". Can you clarify that?
And on the horizontal axis, how many divisions between the positive peaks of the waveform (or alternately use the positive-going zero crossings to find the waveform's period)
this is the graph posted in the question aswell
Better to show the picture:
Okay so i got the first question right, it was asking for the peak not the peak to peak. So for the second part about finding the frequency, I counted roughly 3.2 blocks as the period, so the frequency is just 1/period right? I am not sure what to put in for units though, i thought frequency was measured in Hz, but when i try to put the answer in online it says the units are wrong... any help?
3.2 cm is how much time ?
Problem solved! thank you guys so much for the help :)
