OT: understanding strange technical terms
  • Thread starter Thread starter Micko
    Strange Terms
The discussion centers on understanding the technical term "reference spurs" in relation to phase-locked loops (PLLs). Reference spurs are defined as undesired spikes or noise components in a signal that can interfere with circuit performance. These spurs can originate internally or externally and may significantly impact the effectiveness of the circuit. The term "spur" is clarified as referring to frequency domain spikes rather than its common association with cowboy gear. Further reading on reference spurs is suggested for deeper understanding.
Micko
Hello people,
I'm reading one technical article about PLL and I have found this:
In this second part, we will focus on a detailed examination of two
critical specifications associated with PLLs: phase noise and reference
spurs.
I don't know what reference spurs means? I can conclude from the rest of the text that spurs can be spikes or deviance in reference signal.
Are there other more appropriate terms?
I know that "spurs" are something that cowboys wear, but never saw that technical term.
Can you suggest synonims?
Thanks
A spur in an undesired signal that appears in your circuit. It can be internally generated or come from outside. Obviously if the spur is strong enough it may interfere with your circuit so much rendering it ineffective.
You can read more about reference spurs in particular here:
http://www.national.com/nationaledge/feb01/286.html
In general, the term "spur" refers to spikes in the frequency domain, i.e. undesired noise components of specific frequencies.
- Warren
Very basic question. Consider a 3-terminal device with terminals say A,B,C. Kirchhoff Current Law (KCL) and Kirchhoff Voltage Law (KVL) establish two relationships between the 3 currents entering the terminals and the 3 terminal's voltage pairs respectively. So we have 2 equations in 6 unknowns. To proceed further we need two more (independent) equations in order to solve the circuit the 3-terminal device is connected to (basically one treats such a device as an unbalanced two-port...
suppose you have two capacitors with a 0.1 Farad value and 12 VDC rating. label these as A and B. label the terminals of each as 1 and 2. you also have a voltmeter with a 40 volt linear range for DC. you also have a 9 volt DC power supply fed by mains. you charge each capacitor to 9 volts with terminal 1 being - (negative) and terminal 2 being + (positive). you connect the voltmeter to terminal A2 and to terminal B1. does it read any voltage? can - of one capacitor discharge + of the...
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
