Over-searching error (statistics)
  • Thread starter Thread starter 0rthodontist
    Error Statistics
0rthodontist
I guess this should properly go in the Programming forum, but I think I might get a better response here.
My question is with respect to statistics (context of machine learning) about "over-searching" error. You have a search space S of all possible models, from which you choose a subset K. Then you have some test data D, and you evaluate how well each model in K fits D. You pick the best model in K and use that as your model.
Over-searching says that it is bad to do exhaustive sampling, where K = S. Though the model you end up with fits D better than the model you end up with when K is much smaller than S, for some reason the model when K = S does not work as well when it's tested against new data that's not in D.
I didn't quite catch the reason for this and I still do not understand. I wrote down, "two or more search spaces contain different numbers of models. The maximum scores in each space are biased to different degrees." I understand this but I don't see its relevance to over-searching.
Mathematics news on Phys.org
Difficult to answer without measures for quantifications. The general idea could be: the bigger K the better the fit, but also the tolerances are smaller. This means by additional data to check against, sub optimal solutions can still be solutions, whereas an optimum is likely to be destroyed.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
