Parabolas and hyperbolas - how do you find them?
  • Thread starter Thread starter The_ArtofScience
    hyperbolas
Finding the equation of a parabola or hyperbola requires specifying five points due to the general form of conic sections. By substituting the coordinates of these points into the conic equation, a system of equations can be formed, which can then be solved for the parameters. An example illustrates this process, resulting in a hyperbola that passes through the specified points. However, it is noted that two points alone are insufficient to uniquely define a parabola, as multiple parabolas can pass through the same two points. The discussion emphasizes the importance of having enough data points to accurately determine the conic's equation.
The_ArtofScience
Finding linear equations for initial conditions has never been a problem from me since is easy to see (x1, y1) and (x2, y2) can be plugged into the slope equation. But what if I'm looking for a parabolic or even a hyperbolic line, how do I then find its equation with the initial condition that it must have some (x,y) and (x2, y2) points?
Mathematics news on Phys.org
The general form for conic sections (parabolas, hyperbolas, ellipses, circles, two lines) looks like ax2+bxy+cy2+mx+ny+k=0. Since you can divide by any constant, there are five parameters. Therefore you need to specify the curve at five points.
Well, given that I still don't see a way to make sense out of that general equation since conic secs don't have an actual slope (unless one were to find its many tangents). I'm convinced that there is a way to solve for a parabolic equation given two sets of coordinates though
You plug the coordinates into the equation for each of the 5 points. That gives you 5 equations and 5 unknowns, which you can solve for.
Eg: suppose the curve passes through the following points (im just making these points up):
(1,2); (0,0); (3,4); (-1,3); (-2,-3).
Plugging each point into the equation
x^2+b \cdot x \cdot y+c \cdot y^2+m \cdot x+n \cdot y+k=0,
you get the following 5 equations:
1^2+b \cdot 1 \cdot 2+c \cdot 2^2+m \cdot 1+n \cdot 2+k=0
0^2+b \cdot 0 \cdot 0+c \cdot 0^2+m \cdot 0+n \cdot 0+k=0
3^2+b \cdot 3 \cdot 4+c \cdot 4^2+m \cdot 3+n \cdot 4+k=0
(-1)^2+b \cdot (-1) \cdot 3+c \cdot 3^2+m \cdot (-1)+n \cdot 3+k=0
(-2)^2+b \cdot (-2) \cdot (-3)+c \cdot (-3)^2+m \cdot (-2)+n \cdot (-3)+k=0
Simplifying,
1+2 b+4 c+m +2 n+k=0
k=0
9+12 b+16 c+3 m+4 n+k=0
1-3 b +9 c-1 m+3 n+k=0
4+6 b+9 c-2 m-3 n+k=0
Now you can solve these equations for b,c,m,n, and k.
I went ahead and solved this system of equations since it isn't much trouble, and got the following answers:
b = 116/33
c = -95/33
m = -133/11
n = 257/33
k = 0
So,
x^2+\frac{116}{33}x \cdot y-\frac{95}{33} y^2-\frac{133}{11} x+\frac{257}{33} y=0
Plotting the resulting figure, it looks like a hyperbola, and it passes through all the points we want. Whew!
http://img520.imageshack.us/img520/8662/hyperbolapl5.png
Sorry that you had to go through all that trouble maze. Thanks for the example
Then you are convinced wrong. y= x2 and y= 2x2- 1
both pass through the two points (1, 1) and (-1, 1).
Even given the information that the graph is a parabola, concave upward, with vertical axis, the two points (1, 1) and (-1, 1) are not enough to define a specific parabola.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
