Which Device is Best for Converting Solar Heat to Electricity?
  • Thread starter Thread starter naz1
    Heating Solar
Thermophotovoltaic devices can effectively convert solar heat from parabolic reflectors into electricity. Alternatives like Stirling engines and thermoelectric generators are also viable options for direct heat-to-electricity conversion. Each technology has its own advantages and efficiencies, making the choice dependent on specific application needs. Researching these technologies can provide insights into their operational mechanisms and performance. Selecting the best device will ultimately depend on factors such as cost, efficiency, and intended use.
naz1
how can i obtain a thermophotovoltaic device to convert solar heat from a parabolic reflector to electricity? or is there any other better device that can convert heat directly to electricity?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
