Calculating the Distance of a Parallax Triple Stellar System
  • Thread starter MathematicalPhysicist
  • Tags
    Parallax
In summary, this triple stellar system has a distance of 100 parsecs and can be seen with all three stars using a space-based telescope, but only the binary system can be seen with a ground-based telescope due to limitations in resolution.
371
The question:
A triple stellar system, showing a parallax of 0.01 arcsecond, is composed of a binary system,
with a distance between the two stars of 0.2 AU, and a third star, at a distance of 90 AU from
the binary. This system is observed in the optical (wavelength of 55000 Angstram) with a 1 meter telescope.
a. What is the distance of this system ?
b. How many stars will actually be seen when using a space-based telescope ?
c. How many stars will be seen when using a ground-based telescope, where the typical seeing
is 1 arcsecond ?
My attempt at solution
a. Well, [tex]\theta=0.01[arcseconds][/tex], [tex]D=\frac{\lambda}{\theta}[/tex] where lambda is the wavelenghth given in the brackets, and D is the distance of this stellar system from earth.
Don't know how to do b. and c., any advice?
Thanks in advance.
I would like to provide some insights and answers to your questions.
a. To calculate the distance of this system, we can use the formula D = 1/p, where D is the distance in parsecs and p is the parallax in arcseconds. Substituting the given values, we get D = 1/0.01 = 100 parsecs. Therefore, the distance of this system is 100 parsecs.
b. When using a space-based telescope, we can expect to see all three stars in the system. This is because a space-based telescope is not limited by atmospheric distortion and can provide a clear and detailed image of the system.
c. When using a ground-based telescope with a typical seeing of 1 arcsecond, we can only see the binary system. This is because the third star, which is at a distance of 90 AU, will not be resolved due to the limitations of the telescope's resolution. The seeing of 1 arcsecond means that the telescope can only distinguish objects that are at least 1 arcsecond apart. As the third star is only 0.2 AU away from the binary system, it will appear as one single object and cannot be resolved by the telescope.
I hope this helps to answer your questions. If you have any further doubts or need more clarification, please feel free to ask.
a. To calculate the distance, we can use the parallax formula: d = 1/p, where d is the distance in parsecs and p is the parallax angle in arcseconds. In this case, p = 0.01 arcseconds, so the distance would be 100 parsecs.
b. When using a space-based telescope, all three stars in the triple stellar system will be visible since the telescope is not limited by atmospheric distortion or seeing.
c. When using a ground-based telescope with a typical seeing of 1 arcsecond, only the binary system will be visible. The third star, which is at a distance of 90 AU, will not be visible due to its small angular separation from the binary system. The telescope's resolution will not be able to distinguish it as a separate star.
Related to Calculating the Distance of a Parallax Triple Stellar System
1. How do you calculate the distance of a parallax triple stellar system?
The distance of a parallax triple stellar system can be calculated using the parallax method, which involves measuring the apparent shift in the position of the stars over a period of time. The distance can be determined by using the formula: distance = 1/parallax angle.
2. What is the parallax angle?
The parallax angle is the angle between the line of sight to a star and the line of sight to the same star from a different location. It is caused by the Earth's orbit around the sun, which gives the illusion of the star shifting in position.
3. How do you measure the parallax angle?
The parallax angle can be measured using a device called a parallaxometer or by using a technique called astrometry, which involves taking precise measurements of the star's position over a period of time.
4. What are some challenges in calculating the distance of a parallax triple stellar system?
One of the main challenges is obtaining accurate measurements of the parallax angle, which can be affected by factors such as atmospheric conditions and the brightness of the stars. Another challenge is accounting for the motion of the stars, which can be difficult to determine in a triple stellar system.
5. Why is calculating the distance of a parallax triple stellar system important?
Calculating the distance of a parallax triple stellar system can provide important information about the stars, such as their size, mass, and luminosity. It can also help us understand the structure and evolution of the universe, as well as provide insights into the formation and dynamics of multiple star systems.
