Can a capacitor still function without both plates?
A capacitor requires both plates to function effectively, as the opposite charges create an electric field. If one plate is removed, the remaining plate can still hold some charge, but the capacitance becomes negligible due to the small size of the disconnected conductor. This scenario essentially results in an open circuit, meaning the circuit is incomplete and cannot perform its intended function. The charges will redistribute until the electric field opposes the applied voltage, but the system lacks the characteristics of a functional capacitor. Thus, without both plates, the device is practically rendered ineffective.
kartikwat
What would have been if the opposite and equal charge wouldn't have been induce on 2nd conductor in parallel plate capacitor when connected to a battery
Then you would have an open circuit.
Open circuit means
kartikwat said:
Open circuit means
From Google Search --- which you should learn how to use.
o·pen cir·cuit
noun
noun: open circuit; plural noun: open circuits
an electrical circuit that is not complete.
This can't really happen. Let's imagine that we remove the 2nd plate from the capacitor and leave the 1st plate behind. We will also leave the conductor that used to connect to the 2nd plate disconnected. In this case you will still have a capacitor, as charges will move onto/off of the plate AND the end of the disconnected conductor until the field between them completely opposes the applied voltage. But since the conductor is much smaller than a plate, the capacitance is very, very small. So small that for all purposes you might as well not even consider it a capacitor. Just consider it an open in the circuit.
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
