Parametric Equation Homework: Halfway Around Circle
  • Thread starter notebook3
  • Tags
    Parametric
In summary, a parametric equation is a set of equations that represent the relationship between two or more variables. To graph a circle using parametric equations, a range of values for t is chosen and plugged into the equations to get corresponding x and y values. "Halfway around circle" refers to the point on a circle that is halfway between the initial and final points. To find the coordinates of this point, the value of t can be plugged into the equations. Parametric equations can also be used to represent other shapes such as ellipses, parabolas, and hyperbolas.
notebook3
Find parametric equations for the path of a particle that moves around the given circle in the manner described.
x^2 + (y-2)^2 =4
halfway around counterclockwise, starting at (0,4).
x(t)= ?
y(t)= ?
unsure where to begin...
a(sin2θ+cos2θ)=a
is what you want to have happening with your parametric equation here. So what is x(θ) and y(θ) ?
1. What is a parametric equation?
A parametric equation is a set of equations that represent the relationship between two or more variables. In this case, the parametric equation for a circle represents the x and y coordinates of points along the circle as a function of a third variable, typically denoted as t.
2. How do you use parametric equations to graph a circle?
To graph a circle using parametric equations, you can use a calculator or a graphing software. First, choose a range of values for t, such as 0 to 2π. Then, plug in each value of t into the parametric equations to get corresponding x and y values. Plot these points on a graph and connect them to create a circle.
3. What does "halfway around circle" mean in the context of parametric equations?
In the context of parametric equations, "halfway around circle" means that the variable t has reached half of its range, or half of its period. This would correspond to the points on a circle that are halfway between the initial point and the final point.
4. How can I use parametric equations to find the coordinates of points halfway around a circle?
To find the coordinates of points halfway around a circle, you can plug in the value of t that corresponds to halfway around the circle into the parametric equations. This will give you the x and y coordinates of the point that is halfway around the circle.
5. Can parametric equations be used for other shapes besides circles?
Yes, parametric equations can be used to represent a variety of shapes, including ellipses, parabolas, and hyperbolas. The specific parametric equations used will vary depending on the shape being represented.
