Another useful identity,sin t = 2v/(1+v²)
  • Thread starter Thread starter MercuryRising
MercuryRising
a) find the area bounded by the polar curves r=3sinx, r=1+sinx
first i find the points of intersection, x=pi/6, and x=5pi/6
so to find the area i set up the integral
A= 1/2 integral from pi/6 to 5pi/6 [(3sinx)^2 - (1+sinx)^2]dx
using trig identities, it simplifies to
1/2 the integral from pi/6 to 5pi/6 [3 -4cos2x - 2sinx] dx
integrate and i get 1/2[3x - 2sin2x + 2cosx] from pi/6 to 5pi/6
which the sqrt 3's cancel out so i get (1/2)[ 5pi/2 - pi/2 ] = pi
i think this is correct but my answer is not on any of the answer choices
can someone please check what i did wrong?
b) find the length of the curve from t=0 to t=2pi given the curve has parametric equation
x= t- sint
y= 1 - cost
since the arc length ds is integral of sqrt[ (dx/dt)^2 + (dy/dt)^2]
dx/dt = 1 - cost
dy/dx = sint
thus ds = integral from 0 to 2 pi sqrt[(1-cost)^2 + (sint)^2]
which simplifies to integral from 0 to 2pi sqrt[ 2-2cost]
i couldn't integrate sqrt[ 2-2cost], or did i do something wrong in the steps prior to integration?
thanks
a) I don't see anything wrong with your working or result. I get the same.
b) You're correct up to where you last got to. The integral is doable.
Use the substutution: v = tan(t/2) and it will come out.
are you suggesting trig substitutions?
i thought you can only do that when the integral is in the form A^2 + V^2
You can use trig substitutions at most anytime.
v = tan(t/2)
dv = (1/2)sec²(t/2) dt
2 dv = (1+v²) dt
dt = 2/(1+v²) dv
Also,
cos t = (1- v²)/(1+v²)
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
