Parametric Representations and Parallelism in Linear Algebra Homework Statement
The discussion revolves around parametric representations of a line in linear algebra, specifically addressing the conditions under which two representations describe the same line and the implications for the direction vectors involved.
  • Participants explore the relationship between the two parametric equations, questioning how to establish the equality of points on the line and the conditions for the direction vectors to be parallel.
Some participants have offered initial thoughts on the relationships between the points defined by the parameters, while others emphasize the need for careful reasoning regarding the parallelism of the direction vectors.
There is an ongoing discussion about the assumptions inherent in the problem, particularly regarding the nature of the vectors and the implications of them being representations of the same line.
zacman2400
suppose x=x0+tv and y=y0+sw are two parametric representations of the same line l in r^n
a. show that there are scalars t0 and s0 such that y0=x0+t0v and x0=y0+s0w
b. show that v and w are parallel
a. same line thus
y0+sw=x0+tv
when s0w=t0w then y0=x0 (essentially the solution...I think)
b. not sure at all
I don't like saying because the problem states: parametric rep of same line then must be parallel, but this is the most obvious statement to me
For part b pick any two points on the line [itex]x_1[/itex] and [itex]x_2[/itex] corresponding to [itex]t_1[/itex] and [itex]t_2[/itex], respectively. Since the second parameterization is of the same line then there must exist [itex]s_1[/itex] and [itex]s_2[/itex] such that [itex]y_1=x_1[/itex] and [itex]y_2=x_2[/itex], respectively. Can you take it from there?
leading us to the idea that y1-x1=y2-x2 meaning 0=0, thus parallel
No, you need to slow down and be more careful. You're trying to show that w is parallel to v, which means that w is a nonzero scalar multiple of v.
12K
