Solve Parseval's Identity for 1+\frac{1}{9}+\frac{1}{25}+\cdot\cdot\cdot
  • Thread starter Thread starter TheFerruccio
    Identity
TheFerruccio
Obtain the result of the infinite sum 1+\frac{1}{9}+\frac{1}{25}+\cdot\cdot\cdot
By applying Parseval's Identity to the Fourier series expansion of
0 if -\frac{\pi}{2} < x < \frac{\pi}{2}
1 if \frac{\pi}{2} < x < \frac{3\pi}{2}
2a_0^2+\sum_n{(a_n^2+b_n^2)}\leq\frac{1}{\pi}\int_{-\pi}^{\pi}\! f^2(x) \, \mathrm{d}x.
I got the solution to the Fourier series, and I know it's correct.
The terms for a_n in the Fourier series expansion are \frac{-2}{n\pi} if n=1,5,9,13,..., and \frac{2}{n\pi} if n=3,7,11,15,...
The b_n terms are 0, since it is an even function about 0.
I'm just not sure how to use this information in Parseval's Identity.
so write your sum out and see if you can relate it to the given series
in the infinite limit the inequality becomes equality, and the integral should be easy to evaluate
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
