Partial Derivative of Function
triden
I am doing some gradient questions and having a little trouble understanding the partial derivatives to obtain the gradient. Most particularly in this question:
f(x,y) = \frac{1}{3}(x^{2}+y^{2})^{2}
So to find the gradient we take the partial derivative with respect to x and then y.
I know the answer is
\nu(x,y) = \frac{4}{3}x(x^{2}+y^{2})
but my brain says it should be
why does the (x^2 + y^2) term still stick around? When I do the partial derivative of the x term, do I not treat the Y term as constant? If so, shouldt it disappear?
Thanks
treat the y as a constant when you differntiate only. You must still retain the y, in general the partial derivative w.r.t. x is still a function of both x & y
using chain rule below
<br /> f_x<br /> = \frac{\partial}{\partial x}(x^{2}+y^{2})^{2}<br /> = 2(x^{2}+y^{2})\frac{\partial}{\partial x}(x^{2}+y^{2})<br /> = 2(x^{2}+y^{2})2x<br />
Ah yes, I got it. It was just a stupid logic error in my head. Thanks for the help!
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
