Partial derivatives of function log(x^2+y^2)
Chromosom
I have got a question concerning the following function:
f(x,y)=\log\left(x^2+y^2\right)​
Partial derivatives are:
\frac{\partial^2f}{\partial x^2}=\frac{y^2-x^2}{\left(x^2+y^2\right)^2}​
and
\frac{\partial^2f}{\partial y^2}=\frac{x^2-y^2}{\left(x^2+y^2\right)^2}​
The conclusion is that the following equation is right:
\frac{\partial^2f}{\partial x^2}=-\frac{\partial^2f}{\partial y^2}​
But I can not understand, how can it be possible. The role of x and y variables are exactly the same, then why derivatives are not the same?
Sorry for my English - it is my second language. I am from Poland.
and
There's a factor of 2 missing in all your second derivatives.
The result is exactly as you'd expect. The variable you're differentiating with respect to, matters. If it's x, then y is treated as a constant, and vice versa. So if the "active" variable is leading in the numerator in one derivative, the same should apply in the other. It's just that the "active" variable is x in one case and y in the other, and the other variable acts like a constant.
and
How did you get those partial derivatives? They are wrong.
P.S. There's nothing wrong with your English, and even if there were, there is nothing to apologise for.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
