Partial differentation of two variables
  • Thread starter Thread starter epsilon
    Partial Variables
epsilon
We have a function: ##\phi'(t',x')##.
We want to find: ##\frac{\partial\phi'}{\partial x}##.
I know that the answer is: ##\frac{\partial\phi'}{\partial x} = (\frac{\partial\phi'}{\partial t'} \cdot \frac{\partial t'}{\partial x}) + (\frac{\partial\phi'}{\partial x'} \cdot \frac{\partial x'}{\partial x})##.
I do not know how to achieve this answer. It appears to be some sort of chain rule question, but if you could do through every single step that would be great.
I have actually solved this myself, but thought I would add the answer for anyone else that I wondering how to do it.
Consider the ##\phi'(t')## part first.
##\frac{\partial}{\partial x}\phi'(t')##
We need to have the denominator of the differentiation fraction to be the same function as the function being differentiated. Hence as we are differentiating a function ##(t')##, we need the denominator of the differentiation fraction to be ##\partial t'##.
We introduce ##\frac{\partial t'}{\partial t'}## which is a valid operation as this is just multiplying by 1, which makes no difference to the equation, such that we now have: ##\frac{\partial t'}{\partial t'} \cdot \frac{\partial \phi'}{\partial x} (t')##. I have also moved the ##\phi'## to be the numerator of the second fraction, but this is just a matter of notation.
As it is a multiplication we can swap the denominators around, such that we have: ##\frac{\partial t'}{\partial x} \cdot \frac{\partial \phi'}{\partial t'} (t')##.
This is can be re-arranged to match the answer I wrote earlier, although this is a redundant step, and the ##(t')## does not need to be written anymore either.
##\frac{\partial \phi'}{\partial t'} (t') \cdot \frac{\partial t'}{\partial x}##.
Repeat this process for the ##\phi'(x')## part and then add the two together!
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
