Partial Differential Equation(NEED HELP)
andrey21
Using Darcy's Law given below:
q(x.t) = -k dh/dx
Show that:
-d/dx.(q(x,t)h(x,t)) = phi dh/dt
Can be written as:
K(h(d^(2)u/dx^(2)) +(du/dx)^2)) = phi dh/dt
Any help would be greatly appreciated, I am nt to sure where to begin.
You have:
<br /> \frac{\partial}{\partial x}(h(t,x)q(t,x))=\phi\frac{\partial h}{\partial t}<br />
Insert Darcy's law to obtain:
<br /> \frac{\partial}{\partial x}\left( -kh(t,x)\frac{\partial h}{\partial x}\right)=\phi\frac{\partial h}{\partial t}<br />
Ok I have done what u suggested although think u missed a minus sign out at the front. Do I pull the k outside the brackets??
check the signs...
Ah ok so what is the next step, take out k as I suggested??
Should I use the fact that:
h(x,t) can be represented by:
dh/dt = k d^(2) h/dx^(2)
I was thinking, should tou have q(t,x)h(t,x)? Should it just be q(t,x)?
its q(t,x)h(t,x).
Sorry but the first post contained an error. I need to rewrite the PDE so it becomes:
K(h(d^(2)h/dx^(2)) +(dh/dx)^2)) = phi dh/dt
The k is a constant so that can be taken out of the derivative and then it should all fall into place.
Mat
Ye ok so doing that I obtain:
k(d/dx h(t,x) dh/dx) = phi dh/dt
How do I get to the required answer from here.
Thanks in advance.
Just take k out and differentiate:
<br /> -k\frac{\partial}{\partial x}\right( h(t,x)\frac{\partial h}{\partial x}\right)=-k\frac{\partial^{2}h}{\partial x^{2}}-k\left(\frac{\partial h}{\partial x}\right)^{2}<br />
Rite so:
now differentating:
d/dx h(x,t) = d^2h/dx^2
dh/dx = (dh/dx)^2
is this correct??
Also there is a h missing from the final answer.
Jamiey1988 said:
Rite so:
k(d/dx (h(t,x) dh/dx)) = phi dh/dt
now differentating:
dh/dx = (dh/dx)^2
is this correct??
Remember the product rule? You use it here. (parentheses bolded, because that's the part to concentrate on).
Ah yes:
d/dx(uv) = udv/dx + vdu/dx
so with that in mind:
u =h(t,x)
v = dh/dx
correct?
Jamiey1988 said:
Ah yes:
u =h(t,x)
v = dh/dx
correct?
You got it.
Great, problem is I am nt sure how to differentiate either of those numbers??
Well, what's the partial derivative wrt x of \frac{\partial h}{\partial x}? How about h(x,t)?
well the partial derivative of h(x,t) is
d^(2) h/ dxdt
is this correct?
d^(2) h/ dxdt
is this correct?
Not quite. That is the "mixed second partial derivative" of h(x,t). The partial derivative of h(x,t) wrt x is just \partial h / \partial x.
Ah i see got a little confused there so I now have value for v du/dx as (dh/dx)^2. I just can't work out partial dervative for dh/dx
Just differentiate it again. You should get d^2 h / dx^2
Yes i see now so putting that together I obtain:
u dv/dx + vdu/dx
h(t,x).d^2h/dx^2 + (dh/dx)^2
In the final answer given the h(t,x) isn't there. Do this cancel out?
u dv/dx + vdu/dx
I see an h in your original post. I think that's the h(t,x) we're talking about, and so I'm pretty sure it is there.
Ah great thanks Char.limit for all ur hep.
No problem at all.
Hey char.limit I have another question which is posing a few problems.
Given the following pde:
du/dt = y^2 d^2u/dx^2
where t> 0 0<x<L
where L is 4000 and Y^2 = HK/phi
if t=0 is the time when river flow is altered, write down an initial condition for u.
Again bit unsure where to start on this one.
