Partial differential = the change?
rsaad
partial differential = the change??
How is
Δy/Δx = \partial y / \partial x ?
I just don't know the logic behind this.
That is only approximately or asymptotically true. If Δy and Δx are small Δy/Δx will be near ∂y / ∂x.
rsaad said:
How is
Do you understand how \Delta y/\Delta yx\approx dy/dx\ ?
Usually, x & y are independent variables -- and often there are additional independent variables.
If f is a function of independent variables, x and y, then we write f(x,y).
\partial f/\partial x\ \ is essentially \ \ df/dx\ \ if we treat y as being held at some fixed value.
Then \ \ \Delta f/\Delta x \approx \partial f/\partial x\ \ keeping y fixed at some value.
By the Way: If x & y are independent variables, then \ \ \partial y/\partial x=0 \ .
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
