Partial fraction decomposition
In summary, Tony provided a summary of the conversation, which included the following: -People are having trouble with one more problem, and-The partial fraction decomposition for the erational expression is 8x^3-2, x^2(x-1)^3\frac{-8x^3-2}{x^2(x-1)^3}, and \frac{A}{x}+ \frac{Bx+C}{x^2}+ \frac{D}{x-1}+\frac{Ex+F}{(x-1)^2}. -When the denominator is either lineair (ax+b), or lineair
TonyC
86
Having trouble with one more problem:
find the parial fraction decomposition for th erational expression:
-8x^3-2
x^2(x-1)^3
[tex] \frac{-8x^3-2}{x^2(x-1)^3} = \frac{-8x^3-2}{(x+0)^2(x-1)^3} [/tex]
[tex] \frac{A}{x} + \frac{Bx+C}{x^2} + \frac{D}{x-1}+\frac{Ex+F}{(x-1)^2} + \frac{Gx^2+Hx+I}{(x-1)^3} [/tex] if I remember correctly.
From there its just like any other PFD problem.
Got it...whiz bang!
I came up with -6/x -2/x^2 + 6/x-1 + 4/(x-1)^2 + 10/(x-1)^3
Well?
You don't need lineair and quadratic expressions in the nominators.
When the denominator is either lineair (ax+b), or lineair to a certain power (ax+b)^n, the the proposed nominator is just a number.
It's only when the denominator is a quadratic with discriminant < 0 that the nominators is proposed to be lineair. Quadratics in the nominator never appear.
So the proposed partial fractions are:
[tex] \frac{A}{x} + \frac{B}{x^2} + \frac{C}{x-1}+\frac{D}{(x-1)^2} + \frac{E}{(x-1)^3} [/tex]
@Tony: I see a lot of right nominators but many signs are wrong.
I'm still a bit foggy:
[tex]\frac{A}{x} + \frac{B}{x^2} - \frac{C}{x-1}-\frac{D}{(x-1)^2} - \frac{E}{(x-1)^3} [/tex]
I am coming up with negative numbers each time I run it.
Have you tried with my proposal of partial fractions?
This is what I came up with: I am getting negative signs each time I run it.
[tex] \frac{A}{x} + \frac{B}{x^2} - \frac{C}{x-1}-\frac{D}{(x-1)^2} - \frac{E}{(x-1)^3} [/tex]
What do you mean you run? Negatives? You still have the undetermined coeffecients :S
I have the nominators, they aren't a problem. I have run this several times and have come up with different answers each time.
When I said negative, I meant to say minus.
Well, if you factor again and compare to the initial fraction, you get
[tex]\frac{{x^4 \left( {a + c} \right) + x^3 \left( { - 3a + b - 2c + d} \right) + x^2 \left( {3a - 3b + c - d + e} \right) + x\left( {3b - a} \right) - b}}
{{x^2 \left( {x - 1} \right)^3 }} = \frac{{ - 8x^3 - 2}}
{{x^2 \left( {x - 1} \right)^3 }}[/tex]
This can give you a (not too hard) 5x5 system, or you could simplify your calculations a bit by choosing smart x's, i.e. zero's of the denominator.
I am still lost!
How did you get your first answer then?
"I came up with -6/x -2/x^2 + 6/x-1 + 4/(x-1)^2 + 10/(x-1)^3
Well?"
After simplifying the equation, I came up with 2 different answers:
This is why I asked for assistance. I am truly lost at this point.
But what exactly is the problem? How did you manage to get that first answer?
You can probably use the same method to solve what I wrote.
[tex] \frac{6}{x} + \frac{2}{x^2} - \frac{6}{x-1}-\frac{4}{(x-1)^2} - \frac{10}{(x-1)^3} [/tex]
You have posted a number of times that you get "negative answers" (which isn't necessarily wrong), that you get two different answers, and that you are lost but you still haven't shown what you have done so we could point out possible mistakes!
You want to find A, B, C, D, E so that
[tex]\frac{-8x^3- 2}{x^2(x-1)^3}= \frac{A}{x}+ \frac{B}{x^2}+ \frac{C}{x-1}+ \frac{D}{(x-1)^2}+ \frac{E}{(x-1)^3}[/tex]
TD wrote the left side of that as a single fraction but I think it is easiest to multiply both sides of that by x2(x-1)3 to get
[tex]-8x^3- 2[/tex]= Ax(x-1)^3+ B(x-1)^3+ Cx^2(x-1)^2+ Dx^2(x-1)+ Ex^2[/itex]
The easy thing to do is take x= 0 so that
[tex]-2= -B[/tex] or B= 2
and then take x= 1 so that
[tex]-10= E[/tex].
Since those are the only two x values that make things on the right side 0, you now have two different ways to find A, C, D.
(a) Multiply the whole thing out and combine like powers of x
(b) Use simple values for x, like -1, 2, -2, to get three equation for A, C, D.
What is partial fraction decomposition?
Partial fraction decomposition is a method used to break down a rational function into smaller, simpler fractions. It involves expressing the rational function as a sum of individual fractions with specific denominators.
Why is partial fraction decomposition useful?
Partial fraction decomposition is useful because it allows us to simplify complex rational functions and make them easier to work with. It can also help in solving integrals and differential equations.
What are the steps for performing partial fraction decomposition?
The steps for performing partial fraction decomposition are as follows:
1. Factor the denominator of the rational function into linear and irreducible quadratic factors.
2. Write the rational function as a sum of individual fractions, with each fraction having a specific denominator.
3. Equate the numerators of the individual fractions with the original numerator of the rational function.
4. Solve for the unknown coefficients by setting up and solving a system of equations.
5. Write the final answer as a sum of the individual fractions with their respective coefficients.
Can all rational functions be decomposed using partial fraction decomposition?
Yes, all rational functions can be decomposed using partial fraction decomposition. However, some may result in complex or imaginary coefficients.
Are there any restrictions or special cases when performing partial fraction decomposition?
Yes, there are a few restrictions and special cases when performing partial fraction decomposition. These include:
1. The degree of the numerator must be less than the degree of the denominator.
2. If the denominator has repeated factors, additional terms may be required in the decomposition.
3. If the denominator has nonreal complex roots, the decomposition will involve complex coefficients.
  • Linear and Abstract Algebra
  • Precalculus Mathematics Homework Help
