Partial Fractions but in Complex Analysis
Fellowroot
Use partial fractions to rewrite:
(2z)/(z^2+3)
none
I did this:
(2z)/(z^2+3) = (Az+B)/(z^2+3)
2z = Az +B
A = 2, B = 0...problem is that it just recreates the original
Here is their example in the book:
1/(z^2+1) = 1/(2i(z-i)) - 1/(2i(z+i))
I don't understand how they came to their conclusion in their example.
Any help understanding their example or my question is appreciated.
factor 1/(z^2+1) as 1/(z+i)(z-i)
then 1/(z^2+1)= A/(z+i)+ B/(z-i)
now solve for A and B... what do you get .
and then you can do the same trick on your problem
(2z)/(z^2+3)
none
I did this:
2z = Az +B
Of course it does. You wrote it in exactly the same form. Why would you expect anything else?
You titled this "Partical fractions but in Complex Analyis"- so use complex numbers:
z^2+ 3= (z+ i\sqrt{3})(z- i\sqrt{3}).
Your partial fractions should be
\frac{2z}{z^2+ 3}= \frac{A}{z+ i\sqrt{3}}+ \frac{B}{z- i\sqrt{3}}
Thanks guys, oh my gosh
I actually did their example and set it up all correctly
I got to the end with A+B=0, A-B=0 and without solving it, it just looked like a contradiction and I didnt realize that B=-1.
thanks for pointing that out for me, i was like 99% there and got stuck. i hate that
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
