Particle Distance/Velocity - Natural Logarithms
The discussion revolves around solving a problem involving particle distance and velocity, specifically using the equation v(t) = v0 e^(-at). The initial poster struggles to understand how to approach the problem, particularly how velocity relates to total distance traveled. It is clarified that the particle never truly stops, as it requires infinite time for v(t) to equal zero, but it can be considered practically stopped in a measurable timeframe. After receiving hints, the poster realizes they can use the v0/a solution to find the answer, indicating a breakthrough in understanding the problem. The conversation highlights the importance of guidance and collaboration in tackling complex mathematical concepts.
Chase.
I'm going to post an image due to the complex syntax in the problem...
I'm not going to lie... I really have no idea where to even begin with this problem. Because it says total distance traveled by the particle, I'm assuming that the total distance would be the distance equation multiplied by two; I'm not quite sure where velocity fits in however.
If I'm way off base, I'm still not looking for anyone to explicitly write out the answer for me. I just want to get headed in the right direction.
First thing you have to determine is when the particle stops. Look at that equation: v(t) = v0 e^(-at). Does v(t) ever actually equal zero?
You need an infinite amount of time before the particle actually stops. In practical terms, the particle will be found to have slowed practically to a stop in a measurable amount of time. However, for this theoretical exercise, t has to be infinitely large before v becomes zero.
At this point, e^(-at) vanishes (becomes zero). Can you now find the value of s at this point?
Chase, the ball is back in your court. Show us what you have done, using the hints given by Courious3141 (this is, in fact, a very easy problem and Courious3141 gave very goo hint) or this thread will be deleted.
I'm not sure why this response was so aggressive.
Anyway, thanks Curious! I figured it out. I had initially considered the v0/a solution but discounted it because I didn't think I could input v0 in the submission box.
Glad you got it.:smile:
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
