Pascal's principle/pressure/viscosity
  • Thread starter Thread starter ally1h
The discussion centers on applying Pascal's principle to a fluid dynamics problem involving a large storage tank filled with water. Key parameters include a tank diameter of 10m, water density of 1000 kg/m³, and viscosity of 1.0x10^-3 Pa·s. The problem requires calculating atmospheric pressure, flow rate from a smaller pipe with a diameter of 0.05m, and the force needed to hold a patch over a square hole in the tank. The calculations utilize fundamental equations such as P = F/A and P = Patm + ρgd.
  • Understanding of Pascal's principle in fluid mechanics
  • Knowledge of fluid properties: density and viscosity
  • Familiarity with pressure calculations in static fluids
  • Basic proficiency in algebra and unit conversions
  • Calculate atmospheric pressure using P = Patm + ρgd
  • Determine flow rate from the smaller pipe using the continuity equation
  • Analyze the time required to empty the tank based on flow rate
  • Calculate the force exerted by the patch using P = F/A for the square hole
Students in physics or engineering disciplines, particularly those studying fluid dynamics, as well as educators seeking to illustrate practical applications of Pascal's principle and fluid mechanics concepts.
ally1h
A large storage tank (diameter 10m) is filled 10m deep with water (density= 1000 kg/m^3, viscosity= 1.0x10^-3 Pa*s). The outlet at the bottom consists of 2 pipes, as shown. The large pipe has a diameter d2= 0.1m, and the smaller have a diameter d3= 0.05m and length of 20m. A pressure and flow gauge at point A indicates an absolute pressure of 1.95x10^5 Pa, and a velocity of 6 m/s for the water inside the large pipe. You may assume points A,B, and C are all at the same height, and that the height is 0.5m above the bottom of the tank.
Link below takes you to the diagram...
http://farm4.static.flickr.com/3073/2728597416_16e9339014.jpg?v=0
a) Determine the atmospheric pressure. (Warning: it will not turn out to be exactly 1 atm.)
b) If the outlet of the small pipe is atmospheric pressure, how many cubic meters of water leave the tank each second?
c) How long will it take to empty the tank? (Assume the outward flw is a constant for this calculation!)
d) Find the water velocity and pressure at point B, inside the smaller pipe.
e) At point C, the storage tank has a square hole, 5cm x 5cm. A little dutch boy is holding a patch in place over the hole. How much force does he have to exert (horizontally) to keep the patch in place? Explain the reasoning.
Pascal's Principle
101.3 Pa= 1 atm
P = F/A
P = Patm + ρgd
Wow... I am baffled as to how I should even start this. Trying to a) brought me to exactly 1 atm so obviously THAT isn't correct. I am at a complete loss...
Please, someone help?
12K
10K
  • · Replies 18 ·
12K
