Passing information faster than speed of light
  • Context: Undergrad
  • Thread starter Thread starter leonid.ge
The discussion revolves around the implications of using entangled particles for determining a lottery winning number, specifically addressing whether this process allows for the transmission of information faster than the speed of light. Participants explore the theoretical framework of quantum entanglement, measurement timing, and the nature of information transfer in this context.
  • Some participants propose that measuring entangled particles on Mars could allow astronauts to know the lottery winning number before light from Earth reaches them.
  • Others argue that the results of the measurements are random and cannot be controlled, thus not allowing for faster-than-light information transfer.
  • A participant mentions the practical application of this concept in cryptographic key exchange, noting that while the key can be shared, the actual messages transmitted still adhere to light speed limitations.
  • There is a discussion about the implications of measurement timing, with some questioning whether a delayed measurement on Earth could lead to Martians knowing the result before it occurs.
  • Participants highlight that measurements are spacelike separated, meaning their time ordering is frame dependent and lacks physical meaning in terms of causality.
  • One participant acknowledges a misunderstanding regarding the implications of spacelike separation and its effect on cause-effect relationships.
  • Another participant clarifies that while many believe special relativity preserves cause-effect relationships, this does not apply to spacelike separated events, which do not exhibit such relationships.
Participants express multiple competing views regarding the nature of information transfer and causality in the context of entangled particles. The discussion remains unresolved, with differing interpretations of the implications of quantum mechanics and relativity.
There are limitations regarding the assumptions made about simultaneity and the interpretation of measurements across different frames of reference. The discussion also touches on the ambiguity of time conventions when comparing events on Earth and Mars.
leonid.ge
TL;DR
Can two parties on remote planets instantly use same random number generator with entangled particles?
Say there is a lottery on Earth with 16 bit numbers (from 1 to 65535), i.e. 65535 lottery tickets are sold. Now, we take 16 pairs of entangled particles, 1st particle of each pair is kept on Earth, 2nd particle sent to Mars. The winning number is randomly chosen (on Earth) by checking the spin of each of the 16 particles and combining those zeros and ones into a number. Suppose the lottery draw takes place on Earth at 00:00 GMT. Then if astronauts on Mars check their particles at 00:01 Earth GMT time, they will know the lottery winning number just 1 second after the lottery was drawn, whilst the light travels from Earth to Mars say 20 minutes. Where is the mistake here?
No mistake.
They could even do their measurement 2 s earlier and then know the winning number a second before the lottery is drawn.
@leonid.ge There is even a practical application - cryptographic key exchange. Once the number is known to both sides, they can use it as the key for exchanging encrypted messages. It's like a sheet in a one-time-pad, but with no need to distribute the physical pads.
(Of course there is much more complexity involved in setting up a practical quantum key distribution system, but the general idea is pretty much what you describe).
There's no mistake as far as your description of what happens. However, what happens does not count as transmitting information faster than light, because neither end (Earth or Mars) can control what the results of the spin measurements are; as you note, it's equivalent to randomly selecting 16 bits.
  • Agree
It's worth noting, though, that the actual messages that get sent with this encryption system travel at ordinary light or slower than light speeds.
leonid.ge said:
TL;DR Summary: Can two parties on remote planets instantly use same random number generator with entangled particles?
What if the Earth measurement was delayed and happened at 00:02. Do the Martians know the result before it happened? Did the Earth people send information back in time?
You're missing the point. I doesn't MATTER who measures first. When the Martians measure first, they record the results and then the Earth measurement is already determined. If the Earth measures first then they record the result and the Martian's measurement results is predetermined.
No information is being sent because neither side has any control of WHAT is measured. They are NOT making a setting, they are ONLY recording what happens, which is random.
My questions were rhetorical.
Took me a moment.
martinbn agrees with the rest of you. He was directing this to the OP for consideration, in the hopes the OP would see the obvious flaw in it:
Did I get that right, martnbn?
Indeed... I wrote a careful and thoughtful reply, then noticed that the quoted text I was replying to was you, not OP :smile: :smile: :smile:
Well, in situations like this I use my English as an excuse. It is very difficult to express yourself when you don't use your mother's tongue (the language of mathematics :smile:).
IMO, it's a British versus American thing. Your post seemed obvious to me.
In addition to everything else, there's also a fundamental ambiguity about what GMT means for an event on Mars. There is not an absolute simultaneity convention that allows you to say that an event on Mars occurs at the same time as an event on Earth.
Note that is also true for events separated across the Earth, but the magnitude of the ambiguity is generally not significant.
The measurements are spacelike separated, which means their time ordering is frame dependent, and therefore has no physical meaning. In other words, there is no invariant fact of the matter about which one occurs first. The results just have to be correlated in the appropriate way for the state of the entangled particles. And since there is no actual information being sent, there is no issue about which direction in time information goes.
I have always been under the impression that the special relativity effect on clocks was never enough to change a cause-effect relationship between two events. In other words, all inertial reference frames would agree on which event in a cause-effect relationship with another event happened first.
CORRECTION: I made an elementary mistake. I didn't realize the significance of "spacelike-separation".
That's a common viewpoint, although it actually is not required by SR. But if you take that viewpoint, then you must also accept that there is no cause-effect relationship between spacelike separated measurements on entangled particles. And this makes sense in terms of standard QM, since standard QM predicts that the results of the measurements are the same regardless of the order in which they occur. That's not something one would expect from two events that are in a cause-effect relationship.
I agree that is a dilemma. But I would hate to give up all time sequencing in spatially separated events because of entanglement in QM.
This just seems like too much to me in the general case.
Yes, and if two events are spacelike-separated then there can be no cause-effect relationship between them - and that is when “which happened first” is frame-dependent.
We avoid all of this by stating the relationship in invariant terms: causes lie in the past light cone of effects. This formulation works in non-inertial frames and even physically reasonable curved spacetimes.
You have to give that up regardless of entanglement in QM. It's a basic principle of relativity.
Sorry. I made an elementary mistake. I didn't realize the significance of "spacelike-separation".
  • · Replies 24 ·
  • · Replies 56 ·
  • · Replies 22 ·
  • · Replies 63 ·
10K
  • · Replies 19 ·
